Melted a piston - unsure why.
ive been happy since i decided to only buy from shell.
my pickup has seen 14-20psi for years without tune mods and my timing is pretty aggressive, especially compared to what you have said you use here. i dont even start pulling timing until about 6psi.
i guess i could have driven through some bad gas as long as the pcm has compensated for it. it would be cool if GMs had the same sort of indicator that the evos have with the blinking cel on knock.
I wanted to see what the OEM tune is on that thing to confirm what we have talked about above regarding the AFR being in the 10s and the timing probably still being conservative. I'm guessing HPTuners just doesn't support that vehicle much which is why I can see hardly any parameters in the channel list when scanning it.
Anyone with HPtuners know how to make the scanner pick up more channels including the factory wideband on that thing?
I was working at a Ford dealer so I was using Ford's IDS and could see anything. You could go in the tune and see what it is commanding, but from what I've seen a Ford calibration is like trying to read Japanese vs Chevy being English
Edit- 13 ecoboost escape should be a 1.6L
11 psi, pump 91, cheap intercooler, 15 degrees, AZ, sounds like it was on the edge.
To your E85 question, I've been researching and talking to my tuner buddy, and for my cammed SBE combo I plan to run max of 11 degrees on E85.
