Melted a piston - unsure why.
THUS every LS engine I assembly has been so marked for a "0" TDC Reference.
The ECU-882C I manufacture has that ability, the ABILITY to MAKE sure "0" TDC is read/calibrated TO BE CORRECT.
WHEN the ECU states 11* of crankshaft position that VALUE would then be known to be accurate.
The OEM GM PCM just guesses at the crankshaft position !
Lance
also thank you for that Luke, I’ll go convert 60* c to F so I know what I’m looking at lol
lamda never changes. 1.00 is the same on methanol, E85, pump etc etc. 0.80lamda indicates that there is less oxygen in the exhaust (rich) in comparison to 1.00 (stoich) or 1.30 (lean)
lambda is what AFR should be referenced by to be correct.
Stoich is 1.00 lamda. from that number you get AFR. 0.80 lamda is 80% of stoich value and 1.30 is 130% of stoich value.
petrol stoich 14.7 so .80lamda is 11.76 1.30 lamda is 19.11
E85 stoich 9.6 so .80 lambda 7.84 1.30 lamda is 12.74
meth stoich 6.45 so .80 lambda 5.16 1.30 lambda is 8.38
when you select different fuel on a dyno or wide band monitor to display the right numbers is all calculated off lamda. O2 sensors read lambda and we calulate that to and AFR number.
a lot of people use pump scale for all fuel in communications which is technically incorrect. so to answer your question youre not going leaner than stoich with E85 and lower with pump. both fuels are as you refered to in AFR 0.76lambda. which is 76% or stoich lambda 1.00
correct terminology would say 11.2 AFR for pump and 7.44AFR for E85
Lance
Anyone installing an aftermarket ecu who does not do this...does need a little slap though.
Although in many respects it could be deemed irrelevant. The engine will want whatever it wants, whether those numbers reflected on a computer are "correct" or not matters less as long as the engine/plug is seeing the timing etc it wants.
Of course it would be silly not to have everything baselined as correct so all numbers and values make sense. But it isnt essential.
Really....dont make it stupid rich, dont make it stupid lean, and dont detonate it. After that it should be hard to make a *****.
I have fit UEGO Sensors in Turbo engines for over 32 years including the OEM Vector Car.
I should ADD, the placement of the sensor "manifold BEFORE the turbo", gas pressure effects the read.
I should add the placement of the UEGO semsor, "after the turbo into the exhaust system", a high back pressure exhaust system effects the read.
MY ECU-882C corrects for this "drift"effect when MAP is added the the UEGO Scaling.
Lance
The board you ARE USING may (?) HAVE FOUR CHANNELS OF A/D ALLOWING YOU TO measure THE PRESSURE CHANGE IN each FLASK ( BARO Sensor for each flask), THUS FLOW MEASUREMENT !
NOW, log the PW, Frequency, Duty Cycle, Pressure change.
Your Machine will be improved.
Lance
Now! IN the Future; Tuttle will be confused with Buttle? A very merry unbirthday to you! YES YOU.
hilariousness!!! Now! IN the Future; Tuttle will be confused with Buttle? A very merry unbirthday to you! YES YOU.
MY METHOD ( the invention, circa 1986) of Crankshaft Acceleration Measurement WILL NOT ALLOW this type of damage to happen. (a 60-2 TW, the NOW NAMED GM 58X)
The crankshaft position measurement (GM 24XE) IS the cause, SORRY.
Lance
