ls1 alternator relocation bracket belt issues
Old Jun 30, 2018 | 03:22 PM
BAN_ONE's Avatar
Default ls1 alternator relocation bracket belt issues
I have the on3 bracket they send with their kits and belt keeps coming off the crank pulley by one rib towards the front bumper. messed with the alternator all day yesterday got it to where the belt was staying on at idle but went for a short lap around town like 3-5 minutes came back and it had jumped over the pulley a rib again. ideas? with just the bracket and spacers they sent it set behind the crank pulley around 1/4" I've brought the alternator out with some washers and it's now flush with the crank pulley but still having the same problem. ideas?
Old Jun 30, 2018 | 04:12 PM
red fury's Avatar
I would shim it out a little further.... If you can. If not trim one rib off the belt with a box cutter and new blade. You can roll it like that until you get it figured out.
I had a similar issue when I tried to run the "Big 3 Racing" high mount alt relocation bracket. I had to trim my 6 rib down to a 4 rib belt. It worked just fine, just hated that it was not fitting properly. I switched over to the CBR relocation bracket and the fit was perfect out the box!!
Old Jul 1, 2018 | 12:08 PM
BAN_ONE's Avatar
it looks like cbr removes the idler pulley by power steering too? so its just alt, power steering, crank n water pulley is that right?
shredded the belt yesterday going down the highway so im definitely wanting something else
Old Jul 1, 2018 | 01:10 PM
red fury's Avatar
I kept the pwr steering idler pulley too due to my turbo placement. The belt size you will need is a 780K6 if you go to a belt specialty store. If you go to a regular parts store... The belt I am using is a BANDO 6PK1980.
Thats if you are running stock alternator pulley, stock sized crank pulley.
Old Jul 1, 2018 | 01:32 PM
BAN_ONE's Avatar
is there some kind of advantage to keeping the idler pulley?
Old Jul 1, 2018 | 02:28 PM
red fury's Avatar
I do not see how... Just my opinion
Old Jul 9, 2018 | 05:36 PM
BAN_ONE's Avatar
thanks for the recommendation have this on the car now. their bracket is a much better design belt set up is great now.. like you said works right out of the box.
Old Jul 10, 2018 | 07:48 AM
red fury's Avatar
Great!!!
