Does this recipe actually work?
Old Jul 17, 2018 | 06:16 PM
  #41
8.Lug's Avatar
Originally Posted by chiaj144
Guess you couldn't read the free or cheap part. Why spend money on a cam for 500-600?? It makes a **** ton of torque and responds well to boost.
Guess you still couldn’t read the part where this cam will give you like 6 more hp. If you’re dumb enough to rip apart the whole front of a motor for that - serves you right for the almost unnoticeable power gains you get.
Old Jul 17, 2018 | 06:59 PM
  #42
Krom's Avatar
I'm just some random guy on the internet, but I wouldn't change to arp hardware for the rods or mains without having them resized afterwords.
Old Jul 17, 2018 | 07:19 PM
  #43
Dimeomboost's Avatar
I assumed mentioning new bearings with arp hardware implied machining for both but to be clear I wouldn't put any new bolts with extra clamping force in a motor without a way to measure clearance and money for a line bore and rod resize both a cheap insurance for a long lasting motor
Old Jul 17, 2018 | 10:48 PM
  #44
chiaj144's Avatar
Have you ran this cam? Have you ran it with a turbo? I've made almost 600rwhp with this through a th400 at 12.8lbs of boost. I didn't dyno the stock cam but the car went 130mph with 15lbs of boost and 134mph with 12.8lbs. Different day so not apples to apples but it did pick up. I'll take your 6 horsepower all day long.
I can pull the water pump, timing cover in a few minutes and I like a fresh timing set in my junkyard motors so I'm not pulling the WHOLE front of the motor for the cam swap.. Quit reading internet tales and go do some of your own testing.
