What’s the difference between cheap turbo & name brand?
On3... the Huron stuff. Probably all related to the VS stuff and come from the same place in China. But they are good for the price.
If you can fit a T6 Turbo... A BW S475 is as cheap as most of that but will make more power and is more reliable. $699 cheap.
the more expensive 'real' stuff is a much newer, better design. the 'ebay' stuff is old tech. these days the durability is pretty good on the cheap garbage. i have a ton of miles on my $250 rev9 turbos with zero problems but my super fancy fp turbo on my evo is in a whole other realm for 5 times the price. both are good buys for their applications.
Aspirations are twin turbo stock ci 5.3 LC9 800 rwhp 50//50 drag daily driver. T56 in a 67 Nova. Might go flex fuel.
Sometimes you get a good cheap part, sometimes you get a bad one, because the tolerances are wide f’in open on cheap stuff - but you’re pretty much guaranteed a good part from a high quality company because the tolerances are really tight - but tight tolerances cost more money.
you can get a couple t4 gt35s that have proven to make about 800wheel on a 5.3 for $500. they might be a little lazy but they will do it. that would leave you the money for higher quality injectors or a better clutch or whatever.
on the other hand, a couple tiny PTE billets will do it for 8x the cost, but they will spool much much better.
work ok so far, but I noticed on the exhaust side the bore wasn't exactly centered, but everything was
line bored so it was true straight thru. If it dies, I will prob go back to a BW-just the T4 is more pricy
than the T6.
than the T6.
OEM brands (ESPECIALLY for commercial use like Borg Warner) will always be most reliable.
Power and reliability don't always go hand-in-hand, look at Precision. Probably the most aggressive wheel designs out there. Those turbos fail more often than teenage marriages.
