On3 performance ac kit fbody
Old Jul 30, 2018 | 09:14 PM
SVTFAN09's Avatar
Default On3 performance ac kit fbody
Hey guys I'm about to purchase the on3 kit for fbody, and I'll be keeping my ac, question is has anyone ran this kit with ac? If so what did you do with the condenser and what not, I spoke to on3 about it but they didn't really have any insight.
Old Aug 1, 2018 | 12:51 PM
Photochop's Avatar
Try to get in on a group buy with Huron Speed. After comparing both kits vs cost on a group buy, Huron is superior in every way. Not a fan boy, just been there and went through that.
Old Aug 1, 2018 | 02:37 PM
Mavn's Avatar
"I MAID THEESE"
do a Huron kit for sure
Old Aug 1, 2018 | 04:56 PM
Black_Sunshine_99's Avatar
The new Huron Speed V3 AC kit is legit AF, don't have to relocate anything and can run a PT88 turbo without issue.
I've got a V1 kit and have had to alot to make changes.
Old Aug 2, 2018 | 09:26 AM
Rawr256's Avatar
You leave the condenser in the factory location, just have to put pushers on it is all. I've been running their kit for 3 years now without issues, put down 728rwhp on a stock bottom end ls1 pushing 200k miles.
I think it applies to all turbo setups but make sure to heat wrap the hot side. First go I didn't and at an idle on a 100 degree day it would slowly climb. Heat wrapped and daily driving through summer no issues even with AC on.
Old Aug 2, 2018 | 03:18 PM
SVTFAN09's Avatar
Alright so modifying of the condenser or a/c lines thats a relief. Did you use the gravity grain option or are you running a scavenge pump?
Old Aug 2, 2018 | 03:20 PM
SVTFAN09's Avatar
What k member are you running and im assuming running a Pt88 turbo is with the intercooler standing straight up i assume?
Old Aug 3, 2018 | 09:20 AM
Rawr256's Avatar
I just gravity drained, no issues.
Old Aug 3, 2018 | 09:58 AM
SVTFAN09's Avatar
What's the gravity drain option if you don't mind elaborating on it
Old Aug 4, 2018 | 10:37 AM
Superman09's Avatar
LS1Tech Sponsor
Thanks for the support and referrals! Jon from Huron Speed here and I would be happy to help get you set up with our V3 AC kit. I can cater the components and specs to your needs and goals. Shoot me an email if interested and I would be happy to go over it with you and get you a great deal on a package!
Jon@HuronSpeed.com Available 7 days a week!
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Aug 4, 2018 | 10:48 AM
SVTFAN09's Avatar
Jon
Will do thanks
Old Aug 7, 2018 | 08:09 AM
Lethalwx69's Avatar
The only big issue I've had with on3 is all the V bands being warped. If you do get it, you'll need to belt sand or hand sand them. Gaskets didn't help until I got them flat enough. Also there are no o2 bungs so you'll have to get them welded, that if you want closed loop. The kit isn't as bad as everyone says but dont think, "$2500 and I'm done". As far as fitment, it fits perfect.
Old Aug 7, 2018 | 09:26 AM
SVTFAN09's Avatar
alrighty I knew it was a one and done type of deal lol
Old Aug 8, 2018 | 03:32 AM
Lethalwx69's Avatar
What kit are you gonna go with?
Old Aug 8, 2018 | 09:04 AM
SVTFAN09's Avatar
Torn at the moment hearing good things about both kits at the moment
Old Aug 8, 2018 | 09:09 AM
Mavn's Avatar
"I MAID THEESE"
Huron speed hands down is the better kit.
-Mavn
Old Aug 8, 2018 | 09:21 AM
Superman09's Avatar
LS1Tech Sponsor
If it helps any, we not only offer support 7 days a week, but we also support this very forum you are on!
Our piping is also warrantied for LIFE to the original purchaser. That alone is worth piece of mind knowing should you have any issues, we have you covered!
Jon
__________________
