My first single turbo build
Well I had fun no matter. I actually did the best by leaps and bounds tonight on my aluminum welding. I’ve barely been able to fuse crap together in the past. Im actually pretty excited it turned out as nice as it did and I didn’t have to grind weld off lmao!
*****edit, I think it will work as I forgot my radiator isn’t pushed down all the way. There won’t be much difference the top of the radiator and the coolant level.
Here’s where I decided it’s going
Cut some end caps out of .090 wall sheet aluminum.
Position it
Weld er up. Fill in the hole.
Welded bottom main fitting on that I made in my lathe and test fit
Time for the top piece the radiator cap goes on. I cut it off a cheap tank I bought and then machined a step on it. You’ll see why in a second. Made the hole bigger so it will snap into place
Weld it from the inside using no filler because of the step
The smaller one came with the tank I had. I’m not sure what size hose they use in China but it’s smaller than 3/8. I couldn’t use that.
Little test fit to see where I want the fitting
And it’s done besides powder coating and drilling a hole in the mounting tab that I made but forgot to take pics of. It’s just a mounting tab so who cares anyways! Lmao
Got home today and my oil pressure line was here and so was my block of rubber. I wasn’t really planning on doing much but I did anyways. Went to my shop and cut my rubber blocks to locate my radiator further forward. Worked perfectly. Holes drilled in it easily. I hooked the hoses back up once I got the radiator and fans back in. Then I decided to work on my oil drain. I had picked up a push lock fitting for 10an hose I have. The hose would not go on for anything. I tried soapy water. Heat. And lithium grease. Nope. I’m not weak either. I gave up because I think either the China hose is slightly undersized or the fitting is the wrong size. It’s supposed to be 10an but it measures .600 between the barbs. I ended up using one of the fitting I had that I didn’t want to use. You screw the collar on to the hose and then screw the fitting into the collar and it locks on the hose. I don’t like it but it should work. If it don’t then I’ll change it.
I bought some Siemens deka 60lbs injectors today. They are 79lbs on our fuel pressure. Should get me to 550-600 on pump gas.
I didn’t do the pressure line yet because I’m waiting on a fitting. That shouldn’t be a big deal to do. I’m getting close guys. I may be able to hear it run this weekend!
My rubber blocks
I really wasn’t planning on referencing fuel pressure. I guess I never thought it was necessary because no one has mentioned it in anything I’ve researched. My first go at this. I was just going to ramp fuel under boost using the map sensor and maf. There’s plenty of people running lower power applications where I assumed when they weren’t running a return line that they weren’t ramping fuel pressure. Maybe I wrong? I don’t plan on running much boost from the start. Right about now I don’t care if I have two psi boost, I just want my car running. Wife is on my *** because I’ve been at this for two months now. I just need to get it going and clean up this mess and get it off of jack stands. My theory is, get what I’ve got now lined out before I start adding more potential things to my potential problems and then I’ve got more crap to handle. Make sense?
All those times you see JY 5.3 turbo builds and they have the stock truck rails (most get the one with the return line) and they have regulators built in that are vacuum referenced. Once boost is in the intake the regulator sees boost and increase fuel pressure by pushing down on the diaphram. They essentially get a return style boost referenced fuel system which is perfect.
I would agree with your train of thought, but your fuel system is not going to work well, and your about to spend money on a fuel pump. Why not think... do it right and do it once! Your spent a lot of money on SCH40 SS what’s a week to get th fuel system done. Also I’m not sure what “low boost” is but your single wyntom 44mm wastegate might not let you get as low as you might think. There is a limit to how MUCH exhaust it will bypass. U might manage 6psi minimum, or hell even 10psi... it depends on a lot of things
