Factory PCM Can it Work with a Turbo ?
Hummm, does it run either hi or low impendence injectors? I was thinking of ordering a set of 70lb'ers because they are the largest I know of that work with a stock pcm
Jose
Closed and open loop mixtures are perfect as is full drivability.
On the stock motor it ran a 11.7 in my Monaro @ 7psi before we did the engine and boost upgrade.
www.chipmaster.com.au
Did you rescale the tables then too...
TTT
I've got a buddy of mine thats working on rewriting the pcm to work with a 2bar map. I'm gonna be testing it on my car so we'll see how it goes.
Code rewritten ,extra outputs added tables extended - only way to run the supercharger with all the safety still in place , daul spark timing tables tec.
http://www.acceleronics.com
I'm still thinking microtech at minium.... For my dual fuel (4 rails 16 injectors) I'll need a staged injection system... Gas starts and idles nice and you get good MPG at cruise... 8 huge alcohol injectors will kick in gradually, eventually taking over as boost builds...
For gas only folks the versafueler should be OK....
