Head Selection on L33
Of course, real world says octane limits how much boost you can reliably use on a higher compression motor. For most, dropping compression and upping boost does the same thing.
But what's interesting about the TFS 205 vs 706 comparison is... that's the same compression. The added flow adds power. Again, more boost takes care of it.
But it's still interesting to see more flow is worth 50HP on a very mild setup. And more compression on a slightly more aggressive setup is only worth about 30HP.
And likewise the 220 vs the 225
Just to see if the extra CNC work is really worth anything in the real world vs as cast
average airspeed is 246-268 fps.
Peak velocity 285-310 fps.
pinch point should not exceed 300 fps
Should be pretty safe numbers.
I'm thinking somewhere in the ~875whp/950wtq range at 24 PSI on pump gas.
No solid E.T. at the track, I couldn't reliably keep boost down on the launch well enough to stick it. I switched to using timing-by-gear and ended up grenading the transmission.
Trap speeds back up the horsepower figures.
