Eboost 2 Spike at WOT
Old Aug 31, 2018 | 12:10 PM
red fury's Avatar
You need to go into the setup menu and check the GP setting. I can't remember but I think mine had a factory default setting that I had to lower for the boost level I started with. It should be at least 2.5 #s or more below your peak boost and that might be too close. Try 5 # below and work your way up
Old Aug 31, 2018 | 01:04 PM
RonSSNova's Avatar
I like to use small diameter fuel injection hose for these setups. No give at all.
Old Aug 31, 2018 | 02:31 PM
stevieturbo's Avatar
6mm hose is fine...and as all boost control like this relies in the movement or air....it's pretty obvious that will happen faster if the pipe is 6" long vs 6ft long, especially if there is only 5, 10, 15psi in use which is often the case and then the time for the valve/gate etc to react, chamber to fill etc etc.
Obviously if you're using 100, 200psi...it may not matter a ****.
