Best Twin Turbo Kit Available
I realize they are MEGA $$$, but doesn't Lingenfelter make a TT for just about every performance minded GM car? (Or at least they used to) And if they don't currently have it, I am sure they would do one for ya, $$ is the only consideration.
Originally Posted by V8_DSM_V8again
LPE was just buying a turbo tech kit and installing it...
02bluefirehawk So u going to show me the design logo for the TT kit for QMP or what
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Secret](https://ls1tech.com/forums/images/smilies3/secret2.gif)
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
A buddy and I just finished up a DIY TT on his 91 Mustang. We've probably got 100 hours apiece in it. We did everything though, new low compression engine, transmission, rear end, fuel system, cage etc... None of it is rocket science like has been mentioned, but there is a TON of work involved. If it's your first time, you might want to try to get in on some else's DIY turbo project. This was our first one, and we learned a TON of stuff. The 2nd time around would be a lot less time consuming, and less expensive.
Here is what I got back from Total Performance on there kit, but didn't get what all is included:
Q:
08/July/2004
"Did you guys make a TT kit for a LS1 Camaro/Firebirds, it seems you site has changed. Pricing and availability please.
thanks,
Mike"
A:
09/July/2004
"We did make a kit although it was never put into mass production. I will repeat it but need the car to do it on. Price is $8500 installed and comes with pumps and injectors. Thanks.
Brad & Gretchen Edington
Total Performance
www.nothingbutperformance.com"
Q:
08/July/2004
thanks,
Mike"
A:
09/July/2004
Total Performance
I'm doing my own but it it will look a bit like that PHAT QMP kit (it takes something pretty cool to make me go ebonic) ... Not because I copied them but because thats what I was think but with air to water. The IC pipes would be hidden, shorter, simpler and the IC's underhood... It will need the "little radiator" and some heater hose up front and the rest of the plumbing.. The CAI pipes to each turbo were exactly what I was thinking.. the same for the turbo location...
I'm probably going to start out with out of the box mid length headers...
Maybe put up a price for me building each of the harder part again for someone else as well where to get the IC's just sell what I could'nt buy off the shelf myself.. etc...
