whos made big power on a t4 and small down pipe?
Old Sep 23, 2018 | 08:08 AM
Game ova's Avatar
Full weight f body 3750#, leaving in vacuum on an 80 degree night. 3 inch DP and China turbo.
Old Sep 23, 2018 | 08:12 AM
stevieturbo's Avatar
Was it not some 10 years ago MM made in excess of 1k on a T4 ? PT88
It's nothing new what can or cannot be achieved. Obviously if you opt for Chinese turbos they will almost never be as efficient as a proper turbo so of course it will make less power
Even here, some 7 years ago
Old Sep 23, 2018 | 03:18 PM
rpturbo's Avatar
Originally Posted by chevyrules85
those are claims that i have seen other people make in other threads. claims that i find to be ridiculous. No, neither of those numbers are large numbers to me, relative to a t4 turbo. those are numbers that i have seen others claim to be the limit of smaller turbos such as the 7875, or the limit of a 3 inch DP.
there is no question in this thread. i just thought it would be an interesting discussion, and a way for people doing research to see what the smaller t4 turbos are capable of. like previously stated. some people cant physically fit a borg warner turbo or a 5 inch DP. i would just like to hear from more people who have made good numbers,dyno or track times, from a t4 turbo such as the 7675 precision or on3 7875.
I know a guy who has a 1st gen s10. On his first go around, his truck had a 1st gen PT76 T4 on it. He didn't have much of a down pipe on it, it had the exhaust out the fender, but on a 5.3 his truck went into the 8's. I won't call him out on here, but he is on here.
Old Sep 24, 2018 | 03:31 PM
JakeFusion's Avatar
Super Hulk Smash
PT88 usually has a 4" DP and can do pretty good numbers on a smaller motor with a lot of lag ~5K plus full spool. So, it's a good track turbo.
Most of the small frame T4s and 3" DP end up around ~800rwhp full tilt. Maybe a little more with E85 or Methanol or closer to 900 through a 6-speed. 5.3 or 4.8 would do better with those turbos relative to back pressure.
If you want 600-800 to the tire, a 7675 with a 3" DP will do the trick. If you have a 5.3L, it'll be more efficient in doing it and still spool up quick ~full tilt around 3800-4K.
Old Sep 24, 2018 | 04:14 PM
Black_Sunshine_99's Avatar
700 whp here with a cast wheel Turbonetics T7875 full 3" exhaust with an electric cutout under the driver floor board through a T56.
Stupid simple setup that's performed beyond my expectations honestly, its now to the point that a Gen IV 5.3 is gonna go in and we're gonna see how far this little dude will go.
Old Sep 27, 2018 | 07:22 PM
Redbull87's Avatar
Engine setup has alot to do with power but as mentioned numerous times..you going to see an average from 6-800hp from t4 turbos and 3" dp. mainly because so many of us are just running simple mild builds as street/strip cars. These arent max effort combos looking to make big numbers..just to say you ran a high number on the dyno. Within the 650-800whp range most of us are quite happy with the performance and run decent times. Being auto or manual is a variance to account for also.
Anyways my numbers are in my sig with rear cutout open at 15psi pumpgas and a water/meth splash 50/50
Old Sep 28, 2018 | 12:31 AM
gnx7's Avatar
Precision GTS76 (T4 rated at 1200hp) Gen1 with a 3" downpipe into a 3.5" exhaust went 9.30@162mph in a 2900lb FD RX-7 with T56 Magnum and 6.2 liter LS setup maxxxxxed out. In reality 3100lbs with driver..... pump $2.50 e85 conservative timing
Running a T4 Precision 88mm turbo now and have to pour in more power to see what it'll do. Tons left on the table.... 163mph so far! Goal is 170mph+. Has a 3.5" downpipe into a 3.5 exhaust dumping behind the rear axle.
