Help me build my 370
Old Sep 22, 2018 | 07:50 PM
Akizzem's Avatar
Default Help me build my 370
Current car setup is stock LQ4/317 heads, pac 1218, ls6 cam. Billet 7875 .96ar T4 turbo, 4L80e, circle d 3600 triple disk, 9 inch with 3.25 gears, on only E85. I知 rebuilding the motor this winter and I知 unsure if I should go with -3.2cc flat tops or -11cc dished Wiseco pistons. I will be using LS9 headgaskets. No head work other than dual springs. I知 also thinking of doing a BTR stage 2 turbo cam 226/231 .605/.598 113+4. But I知 not sure if a stage 3 would be better? I知 also not sure if the 7875 will have too much back pressure on this motor and maybe I should move up to a pt88? Any help would be great
Old Sep 23, 2018 | 07:48 PM
itsslow98's Avatar
On e 85 I would do the -3.2 pistons to bump the compression some.
Old Sep 24, 2018 | 05:50 PM
93camaro_zzz's Avatar
PT88's were cool. In 1997.
Old Sep 24, 2018 | 07:05 PM
JakeFusion's Avatar
Super Hulk Smash
PT8847 would be good on a 370 or a BW S480 .92/T4...
I'd do the 3.2s with E85. Should be fine.
