Boost Controller with NO C02?
Old Oct 1, 2018 | 09:40 AM
Mastif's Avatar
Default Boost Controller with NO C02?
Guys,
I am looking for a good Boost Controller for my 370 Twin turbo car, and looking for the best to fit my needs, and work good of off manifold pressure. Car is a street car, that will see some track time. I do not want to add C02, and would like some opinions please.
I have considered the Boost Lease, E-Boost Street & Go Fast Bits G-Force II.
Any thoughts is appreciated
Old Oct 1, 2018 | 10:12 AM
svslow's Avatar
If your ecu cannot control the boost then a Boost Leash with an on-board air compressor set up would work well.
Old Oct 1, 2018 | 10:14 AM
3 window's Avatar
I went to onboard air and a very soft spring in the gate. Best change I’ve made to the car. I use the $110 Viair kit with the 1 gallon tank.
Old Oct 1, 2018 | 10:34 AM
Mastif's Avatar
Really hoping to stay away from a Air tank. What will be the effect from a controller using Manifold Pressure?
Old Oct 1, 2018 | 10:51 AM
svslow's Avatar
CO2/compressed air will give you the best control of the system. You can run 4psi or 40psi on the fly. Its a huge help at the track.
Old Oct 1, 2018 | 11:14 AM
pdxmotorhead's Avatar
The air tank does not have to be large,, an ARB locker compressor should do the trick unless it loses air at some constant rate? It has a small tank (About 2.5x 6") and runs the 2 air lockers on my jeep its good for 150 fish lbs not horribly high volume, good for about a 50% duty cycle... They do have multiple sizes as well..
Old Oct 1, 2018 | 01:06 PM
3 window's Avatar
Waitin for manifold pressure!
Old Oct 1, 2018 | 01:25 PM
svslow's Avatar
For $100 its hard to beat the Viair kit. Even comes with all the hose you'll need.
Old Oct 1, 2018 | 01:48 PM
Mastif's Avatar
Default Kit
I did look at that kit, I wished the tank was a little smaller.
Old Oct 2, 2018 | 09:16 AM
svslow's Avatar
Here is my tank in the back of the mustang.
Old Oct 2, 2018 | 10:25 AM
stoverz28's Avatar
What spring rates are you guys using with the compressed air? Max boost? I have the 1 gallon VAIR kit sitting on a shelf in my garage and need some motivation to install it.
OP, fwiw I love my eboost2.
Old Oct 2, 2018 | 11:17 AM
3 window's Avatar
I use a 3.5psi spring. It’ll go as high as I want. I run 60 psi head pressure to the solenoids.
Old Oct 2, 2018 | 12:02 PM
svslow's Avatar
I do the same. About 4psi gate spring. Air regulated to 60psi out of the tank. Will make more boost than I need.
Old Oct 2, 2018 | 02:34 PM
Mastif's Avatar
Default Sold me
Okie dokie now, Im Sold
I have decided to order a C02 kit and a boost controller. I will probably buy the Boost Leash, although I keep looking at the Go Fast Bits ( G Force 2). Seems like it should do whats needed for half the money ($270).
Old Oct 2, 2018 | 03:13 PM
vcoupe's Avatar
I have been doing a lot of research about this lately. The only down side to the gfb2 is you cant fine tune ramp. So lets say you have a hard time hooking up at the track or street, ramp rate would be very helpful for this. Beside this the gfb2 is the best bang for the buck boost controller.
Old Oct 4, 2018 | 10:51 PM
j-mart32's Avatar
Haven’t used the go fast bits controller, but the boost leash is awesome. Super easy to use all functions on it. Awesome to have extra power literally at the push of a button. Not saying the go fast isn’t good, but you won’t regret the boost leash at all
