1955 Chevy Roots Blower LSX
Yes they (Both) are heavy and yes they make a lot of heat unless you run Ethanol/Methanol but they also make huge torque down low and look cool hell sticking out of the hood of a classic muscle car. ( Or any car in my opinion) What's wrong with the drivability other than they stick out of the hood?
So, I am in contact with DIY autotune now and will be ordering a MS3Pro Ultimate. I will run 8 new injectors on a custom plate under the Hilborn 4 port and also utilize the exiting injector holes by running water/meth controlled via the MS3Pro. Should make for a VERY versatile and fun ride!!!
On a side note, it is a 8-71 blower...I found this out by measuring the case length from rotor to rotor. So, I have a 16" case which means 8-71. The 6-71 rotor is only 1 inch shorter...and as mentioned, basically not visible unless you lay a tape measure across the case.
I will start getting sensors together (IAT, TPS, MAP, Ethanol Content, ECT,....), make a 36 tooth wheel for the crank and other engine management things. It will get traction control too...just need to add a few other speed sensors and reluctor wheels. Going to hide some LS2 coil packs under the headers and sneak the plug wires up for a clean look. I think the GOAL is to make this a car that NO ONE would drive on the street AND runs 9's....there is no reason why this car/combo could not be a 9 sec all steel cruiser with the right technology.
The build will begin soon once I get a nice mound of parts and plan together. Should be able to get this done before spring time. It is mainly bolt on stuff and wiring....fingers crossed!
I might make the plate "wide" and burry 75% of the injector into the plate. So, if I use short body injectors, you will see very little injector. Not to mention with the hood closed, the plate and injectors will be below the hood. So it will still look freaking awesome!
that lower manifold is interesting... i think some injectors could be fitted in there and would be all hidden under the blower...it would be alot of work though. maybe i'm not seeing something not having one in person to look at
