Here's what scares me without a BOV. 92 mm throttle plate is about 10 square inches. Lets say at 20 psi, you close the throttle. Now you got 20 PSI on one side of the plate and a vacuum on the other side. So let's call it 30 pounds per square inch pushing against a 10 square inch plate or 300 lbs against the plate and shaft.
In theory yes, it's possible a pressure spike might mean even more than that, but the closed blade should be strong and there should be little real strain on the shaft itself. And that's if you choose to fully close the blade at high rpm ( DBW gives you options here )
There are considerations and options all round. It probably does make sense to run a valve, whether one or two ( or more ) is irrelevant as ling as they're sized and positioned to do what you think they need to do. Some may do two purely for aesthetics, rather than actual function etc etc.
But in general, it probably is best to have some sort of escape path for boost on closing or even modulating the throttle at high loads.
When I was new to turbos and was building turbo 4 cylinder cars I installed BOV’s. Fanboi ****! That was over a decade ago. BOV’s are just another place for a leak. You should see the look on people’s face when I tell them I don’t run a BOV. It’s comical that people think you need one.
You don't need hot water in your house either, but it certainly makes life easier on the more sensitive parts. If you run a manual transmission you need a BOV. If you drive hard on the street with an auto, you need a BOV. The only thing that is fanboy **** is the ones that are specifically designed to make some stupid noise when you let off the throttle. There is absolutely no legit reason to induce a severe pressure spike into your intake tubing every time you lift the throttle. That is just begging to blow some connections apart.
