3/8 push rod clearance
Old Oct 5, 2018 | 09:05 PM
liketowork's Avatar
Default 3/8 push rod clearance
I am putting a Cam Motion solid roller turbo cam in my new set-up. I have ported 799 heads. Would it be a good idea to drill out the pushrod holes a little larger?
Old Oct 5, 2018 | 11:34 PM
truckdoug's Avatar
yeah use a 12.5mm drill, you'll probably have to order it online. you only need to go about an inch deep from each side.
Old Oct 6, 2018 | 01:23 AM
liketowork's Avatar
Thanks! I see if I can get a drill from my machine shop buddy
