X pipe on a remote mount Twin Turbo?
My thoughts are to recoat the headers then add sleeves to retain heat, then step down via a long cone from 3" to 2.25", ceramic coat and sleeve those as well... and move the flexi joins right up onto the collectors with a anti-reversion cone that helps velocity and reduces pressure on the flexi joints... an experiment lol.
If budget allows I may spring for short tube headers that step DOWN and make anti-reversion cones on the exhaust flanges (think port extensions with a primary pipe flared right over it creating space above the cones). This should aid velocity and reduce reversion back into the port during overlap.... but for now I'm keeping headers I have as they work and cost nothing but a recoat and sleeves.
Should I add an x pipe before the turbos along the new 2.25" length - or are they not going to add anything on a TT? I currently run no balance tube between sides. Only the intake gets blended as the intercooler runs single inlet/outlet.
Thoughts from anyone that has tried with and without an X pipe pre turbo (only relevant on a remote mount)
I'm going to design a set of shorty's and get them custom made.... more cost but I think it will be worth it. Cast iron manifolds may be better for response but will increase back pressure I fear and I'd rather have a softer power delivery with a stronger top end than vice versa because I often have to race in the wet
re X pipe - I did some research and consensus was it's a bad idea pre-turbo. While it may help velocity on a NA motor, the back pressure from the turbos will likely eliminate that advantage and will simply add volume, therefore reduce response was what I got out of reading on this. Could not find any science or real world hard evidence though.
But they will not be a power limitation at all in a turbo application.
As for X-Pipe....hard one to say one way or another but would be an interesting experiment. Shouldnt be too hard to fab a system to make a swappable H or X section to test ?
