Plugs?
Old Nov 8, 2018 | 09:47 AM
Bearden4242's Avatar
Default Plugs?
I'm sure this has been beat into the ground, but I have reason the believe my application may bring the exception. 5.3 sbe gen 4 lower, lpe 243 heads, btr stage 3 cam, studs, flex fuel capable and/or 93 with methanol inj incase of limited availability, twin 58/65 turbos, 6 speed, 3.73, street car. 10-14 psi max. Car is still being built, motors togather, currently has br7ef. Thoughts? Thanks in advance
Old Nov 8, 2018 | 10:04 AM
ddnspider's Avatar
you're running what I would suggest.
Old Nov 9, 2018 | 10:34 AM
rpturbo's Avatar
You don't think the turbos might be a bit small? Granted, you didn't say a specific hp goal or anything, but I thought most twins on a 5.3 were usually a 62/62.
