Fbody - On3 76mm winter build
At first i had the on3 76/65 and i was able to get a 10.1@140 with that. Then i was given a damaged on3 78/75 and thats what i ran the 9.67 with. Ljms stage 2 cam in a l33 with the 799’s that came on it. Im also auto. I torched the t56 after a few months. Over around 600whp you really need an external pump to lube the “head set gears” the thin trans fluid runs to the back and overheats the gears in the front of the trans. Wish I would have known that before I messed my t56 up lol
The turbo may be my first weak point im assuming
