7875 Turbine OD
Before it is asked Im measuring it properly with a brown and sharpe mechanical dial caliper that was recently was inspected and certified by the company I work for .
My exhaust turbine housing , where it meets the turbine wheel only measure ruffly 83mm so it cant measure 85mm.
If any one could put a pair of calipers to their 7875 turbine wheel or has already done so , it would be great .
Thanks
-Precision, Turbonetics, Comp, VS-Racing, On3, HS
What numbers were you expecting to see when measuring?
For the name "7875" this would indicate typically 78mm measurement for the inducer on the compressor wheel and 75mm measurement for the exducer on the turbine wheel
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I would list the ebay listing for you but I dont know if its aloud . You can always search 7875C one will pop up.
While I have your attention do you happen to sell replacement chra if I ever need one?
