Pistons with too much dish?
Old Nov 30, 2018 | 05:50 PM
Akizzem's Avatar
Default Pistons with too much dish?
Made the mistake of going with dished pistons instead of flat tops (dish is -15cc, flat tops were -5cc) this is an lq4 bored .030 over. I was planning on using the original 317’s but with a 70cc combustion chamber would put my motor at 8.78:1 compression ratio. I have a set of 799 heads as well with the 64cc chamber. That would put my motor about 9.5:1. Would you even be able to feel a difference between a half a compression point? This is a turbo car
Old Nov 30, 2018 | 07:25 PM
LLLosingit's Avatar
Not as much as you would think. HP From CR Change Calculator
Old Nov 30, 2018 | 10:29 PM
Akizzem's Avatar
I wonder how the 799’s would do with boost compared to the 317’s. I know they flow the same but I’ll have to look into it more and find out the differences besides the different cc’s
Old Dec 1, 2018 | 02:37 AM
SteenH's Avatar
It really depends on what your goals are etc.
6 guys do it one way, half dozen the other.
Personally prefer the idea of a low compression motor with extra boost poured into it, but everyone has an opinion.
Old Dec 1, 2018 | 06:12 AM
forcd ind's Avatar
You might have more comp. than you think, LQ4's had dish pistons, not sure the vol., but you
also bored it, which will raise the comp. You could take a slice off your heads, or use 243 heads,
lower comb. CC's.
Old Dec 1, 2018 | 07:28 AM
Akizzem's Avatar
It’s a single billet 7875, 4l80e, 9 inch, 3600 triple disk stall setup with a LJMS stage 2 turbo cam. It’s just a weekend fun car but it will be driven on the street more than the track. The car is also on e85 only, so I now realize I could probably get away with more compression. I’m just worried it’s going to feel gutless out of boost and it won’t be enjoyable to drive under normal conditions
Old Dec 1, 2018 | 07:55 AM
Old Geezer's Avatar
"I’m just worried it’s going to feel gutless out of boost and it won’t be enjoyable to drive under normal conditions".
This is entirely possible.
Old Dec 1, 2018 | 09:30 PM
gsteele's Avatar
Do you think that calculator is wrong?
Old Dec 1, 2018 | 09:34 PM
Akizzem's Avatar
No I think that calculator is pretty accurate it makes sense. I think I’ve decided to just run the dish pistons with the 799 heads. With Ls9 headgaskets it should get me close to stock LQ4 compression of 9.4:1. It’s still on the low side of what I could probably get away with but I think it will work just fine.
Old Dec 1, 2018 | 10:42 PM
jordoza's Avatar
I ran an lsx376 with a single s480 and a tick stage 2. It only had 9 to 1 comp. It was far from gutless out of boost. You will be fine.
Old Dec 3, 2018 | 08:35 AM
Ron_Stoppable's Avatar
it'll work, but its not ideal... especially being on e85. 11:1 would be perfect. 2 points of compression does make a difference, its not the end of the world though.
Old Dec 3, 2018 | 06:39 PM
LLLosingit's Avatar
11:1 on a turbo car?
Old Dec 3, 2018 | 06:46 PM
007FJ's Avatar
LL>>>
On an E85 setup
Old Dec 3, 2018 | 09:43 PM
rotary1307cc's Avatar
I've had compression all over.
All nuts if you think you are going to neuter an engine off boost with a 1pt difference in CR
Old Dec 4, 2018 | 12:49 AM
Game ova's Avatar
9:5 comp 6.0, in a full weight f body here, and a 2:73 gear to top it off..... far from gutless/soggy off boost imo.
Old Dec 4, 2018 | 12:13 PM
im 12:1 with a turbo motor.... really it all correlates to cylinder pressure/ camshaft dynamics in relation to static compression at the end of the day. that's a talk for another time though,,,
Old Dec 4, 2018 | 12:41 PM
BCNUL8R's Avatar
I had a 408 nitrous build with AFR heads on it at 11.1 to 1 static compression. When I eventually hurt that motor I had it rebuilt with dished pistons to lower compression to 9.5 to 1 static for boost. Same cam, same heads, same intake (fast 90), same everything just lowered compression. I drove it for a while with no boost before I ended up selling the car. It was a huge difference in response in street driving. It even sounded different. A point of compression is huge in a street car and I even had cubic inches to help with low end.
Old Dec 4, 2018 | 01:24 PM
gsteele's Avatar
Do you believe that calculator and if so how much hp do you think the 1.5 cost you? That calculator assumes peak hp so I would assume the hp at lower rpms are the same percentage.
Old Dec 4, 2018 | 01:38 PM
BCNUL8R's Avatar
By seat of the pants I’d say lower rpm was way more effected then peak. Keep in mind my comparison was NA to Na. Depending on how your boost comes in it may not be as noticeable. Honestly for me with the only change being compression ratio NA it wasn’t even fun to drive any more on the street even with 400 plus cubic inches. All we did is go from 4.030 bore to a 4.040 bore with custom dishes pistons.
Old Dec 4, 2018 | 02:19 PM
007FJ's Avatar
BC...a lot of that feel likely came from the cam probably being better lobed for the higher compression.
