View Poll Results: Which Turbo?
Voters: 13. You may not vote on this poll
Another help me pick my turbo/setup thread - 6.0/80e
After getting some info from Huron Speed, I think at this point the BW turbo is out. While I think it fits the application a little better, the modifications to the kit mean extra time and money on my part that im not willing to screw with, so the 7875 turbo it is. I will be going with a billet version of one of the 3 chinese turbos, either VS, on3, or HS.
Also talking with them, I was able to glean some info on the HS turbos, and it is not the same as either the on3 or the VS. It has a larger compressor housing and a 6 blade wheel design. I'm going to start digging and see if anyone has real world results from the HS turbo, as I know less blades and larger compressor housing theoretically means it could flow more, but im wondering if it would matter with the hot side being the same all said, and less blades doesn't necessarily mean more flow as other things like design come into play if we are comparing that to the other two which look to me like they use the same blades.
edit: unfortunately HS is out of stock of the house 7875 and the timing just isnt right for when I need to get this completed, so that turbo, while to me is the most attractive of the 3, is probably not in the cards
so now that that settled, on to cam selection.
I have looked at the LJMS stage 2
the summit pro LS stage 2
The tick stage 1
the speed inc tu1 and tu2
or, because its a 6.0, do we think I can make more power on a smaller cam like the triple 12 or ss2 or something with like a -6 overlap?
The tick stage 1
I'm not the voice of wisdom here, just some guy who is still plotting and scheming and doing a wack of research for his turbo LS.
I bought the VS Billet 7875 for my 6.0L. The vehicle will never see the track, it's 100% street driven, and will replace my current daily. I don't spent enough time at the top of the RPM to warrant a massive turbo, but I do want it to light up quick with lots of torque in the rpm range where I actually drive. Might be old age setting in.
I know the "Sloppy Stage 2" is super popular, but that cam needs a converter (and possibly gears?) and both "lumpy" and "converter" usually means poor fuel economy. My current daily is lumpy cam and high stall, and it's getting old (231°@050, 108LSA).
I would shoot for something no bigger than 220°@050, with fairly wide LSA (maybe 114°), but that's just my opinion. As it is, I'm going to just run the stock cam for now, and revisit the cam once it's sorted and I've been driving it a while.
If you're going to track the vehicle, you need to build it for that.
Imo I'd go smaller on the cam like the ljms stage 1 turbo cam, unless you want some lope. I really dont know what I'm talking about tho. Best thing is call ljms and see what he thinks will be best for your setup, or BTR or any cam providing sponsor.
I'm still torn between s475 and 7875. I think Doug makes the most since with the cam I have, big wheel t4. But do I need that much turbine for low 6s 1/8 mile in a 3300lb truck (guessing on weight). And I really dont wanna drop $1k on a turbo, then how much will I have to cut out and move my hotside to fit it. Then how much power difference is there between the small billet s475 that will require some cutting to fit and the billet 7875 that will prob bolt right in? Tax time is just around the corner LOL
I bought the VS Billet 7875 for my 6.0L. The vehicle will never see the track, it's 100% street driven, and will replace my current daily. I don't spent enough time at the top of the RPM to warrant a massive turbo, but I do want it lo light up quick with lots of torque in the rpm range where I actually drive. Might be old age setting in.
My car is 99% percent street driven, does have a nice FTI 3800 hard hit stall, and has what I think most might consider a pretty aggressive gear for a turbo car at 3.50s. If you look at my OP the car is built from the motor back, and currently is really lumpy with a big cam and drives great, I just want to be faster. I am leaning towards what you are saying in a smaller cam as im reading it doesnt cause as much backpressure issues on a smallish turbo on the 6.0 motor and ends up making as much or more power and carrys it lower across the band.
This is all theory though as I have seen lots of other conflicting info too. Im trying not to harass guys like stock48, bryan tooley, or lil john before i get a good enough grasp on how turbo cams work for my setup though.
As for the cam, the more im learning im leaning smaller, with stuff like the ljms stage 2 or the pro ls stage 2 turbo cams being the very top of what would 'work' for this combo. I dont plan on pulling it apoart again so i just want to pick it right the first time.
John Dougherty is who I got my cam from. Stock48, Martin at Tick, John Bewley are all great people as well and will steer you right.
If that is the turbo you want get Jon to give you a time estimate. You have more time than you think. It isn’t a quick job and there is a lot of little time killers just in the power steering, wrapping the hot side and about 200 little time eaters I’m forgetting. You’ll spend more time measuring and remeasuring for oil pan return...brake line and rack clearance to the hot side. How to run the exhaust. Do you want a boost controller. Is it a Formula...guess what...cold side issue with the drivers fog light and bov. Best thing about it all is Jon. He will get back to you quickly. About like Bob when I had the Procharger setup.
I did go ahead and pick up the VSR billet 7875 through HS, so now that is wrapped up I am doing cam selection and should be basically all good to go~ Ill cxheck out john dougherty and see what i can find out, i am getting real close to calling guys, i am continuing to lean a little smaller than the LJMS/BTR stage 2 sized cams unless when i do go to make the final call that im talked out of it.
I read through the thread and little late since you have chosen parts already but for your intended use i agree the billet 78/75 will be perfectly fine for your 6.0. go as large and short travel as you can for the exhaust as to alleviate backpressure issues at high boost. The billet turbo will be peppy on the street in the midrange rpm making it a blast to drive.
I have the On3 84mm and love it,same with my ljms stg 2 cam.I found it rather tame honestly. Its got a good lump to it at idle but drives easily on the street with decent gas mileage out of boost lol. Its aggressive on paper but really not in person.
I actually have a cutout right at the end of the ypipe for my current exhaust set up, so we will just connect that with turbo downpipe and I will run the cutout, but be able to close it when needed.
I ended up going with comp cam 226/230 113+4 .605/.575, very similar to the LJMS cam.
just ordered my deka 80lb injectors.. parts should be here by this weekend~
#32
Thanks for the help boys!
This is base tune only, very fat tune (11.2) with no timing and only 12 pounds of boost. Pump gas 93 octane + meth. Billet VS 7875 on Huron speed v3 kit. Car was spinning its *** off in the cold weather so I was pedaling the hell out of it. Still fun !!
