Stock 6.0 with 7875 turbo
Old Feb 8, 2019 | 09:47 PM
freeky's Avatar
Originally Posted by SkinnyG
I -will- be running PAC1218's with the stock cam in my LQ4, and 15-20psi boost, and a billet 78/75.
But I'm a good five years away from the rest of the truck being complete enough to give you feedback.
i should have the iroc running by halloween so ill update this when its moving . thanks for your input tho are you gonna gap the stock rings tho . i believe youll still need to do that
Old Feb 8, 2019 | 10:26 PM
Lsxford's Avatar
Originally Posted by freeky
video says you need better valve springs to run more boost . anybody have any experience with stock engine just adding valve springs an running 15-20 lbs of boost ?
you prob won't make it past about 12 psi before you start floating the valves. In my experience anyway that's about the spot, different engines and turbos will act different. Best to throw some pacs in and be set imo. They're cheap enough.
EDIT, especially if you're gonna pull it all apart and gap the rings.
Old Feb 8, 2019 | 10:34 PM
SkinnyG's Avatar
I -think- I will gap them 0.028 and 0.030" so that as I turn the wick up, I am less likely to break it.
But part of me thinks I will be perfectly fine sticking to 15psi, in which case I would run .022" and 0.024" or maybe .024" and 0.026".
I haven't decided. It's just going to be my daily; never taken to the track.
Old Feb 9, 2019 | 02:21 AM
freeky's Avatar
https://ls1tech.com/forums/forced-in...e-78-76-a.html
Old Feb 9, 2019 | 02:22 AM
freeky's Avatar
https://ls1tech.com/forums/forced-in...e-78-76-a.html this is a good post about the 7875 turbo
Old Feb 9, 2019 | 02:41 AM
freeky's Avatar
im gonna gap mine at .028 that should be fine for 20 lbs of boost
Old Feb 9, 2019 | 01:06 PM
soloman369's Avatar
bone stock engine ?
yes stock gen 4 internals and flat tops 799 heads. I have a build thread on here go check it out.
Old Feb 10, 2019 | 10:08 AM
freeky's Avatar
do you have a link to your build page
Old Feb 11, 2019 | 10:41 AM
panda240ss's Avatar
home owners asssiation . they tell you what ana how you can do things in a neighborhood
I dont know why i didnt think of that. brain fart i guess but yeah they are communist. i feel they are a scam .
Old Feb 11, 2019 | 10:43 AM
panda240ss's Avatar
im doing a similar build just not opening the block. its a gen 3 stock insides just the pac 1218 and a sloppy stage 2 cam and well on3 7875 regular turbo on e85 and such just want like 600 650 rwhp. hopefully i can get that power dont really want anything above 15psi either.
Old Feb 11, 2019 | 02:33 PM
soloman369's Avatar
https://ls1tech.com/forums/forced-in...5-22-18-a.html
Old Feb 11, 2019 | 02:34 PM
  #32
freeky's Avatar
from what ive read you need to gap rings if above 14 lbs of boost .thats why im doing ring gap . i dont wanna open the block right now . i may just settle for 13=-14 lbs for awhile an when i put cam in pull the block then . i jus wanna get it running right now
Old Feb 11, 2019 | 02:38 PM
  #33
freeky's Avatar
thanks for the link heres my build page . its gonna be a slow build hopin to get engine in an running by halloween .https://ls1tech.com/forums/chevrolet...3M_ryyspuh0ffA
Old Feb 11, 2019 | 03:15 PM
  #34
panda240ss's Avatar
ugh kinda didnt wanna open up the block. then it would be new hg, bolts ect. FML.
or i can just keep it under 14psi.
Old Feb 11, 2019 | 04:07 PM
  #35
freeky's Avatar
from what i been told an read 10-12 should be in the 500s whp range . im doing that until i get cam . ill prolly add springs tho
Old Feb 12, 2019 | 08:05 AM
  #36
panda240ss's Avatar
10-12 psi on pump or e85? i have a sloppy stage 2 cam and might not make a difference but 102 tb with aluminum intake? already have pac1218s.
my friend made 500 on 9psi on e85 with a 4.8
Old Feb 12, 2019 | 01:02 PM
  #37
freeky's Avatar
should be in the 500s with 93 pump . im really thinking about e85 lately. i know a guy that made 780 on pump with a custom grind cam an a gt45 on 12.8 lbs of boost in a 6.0
Old Feb 12, 2019 | 01:07 PM
  #38
panda240ss's Avatar
I Think i can do 600s with e85 and 12 or 15 psi easy. everyone has been saying so that it shouldnt be a problem.
im switching because i live down the street from a e85 station. so i shouldnt have a problem fueling and its so much better for the car since im going F.I
Old Feb 12, 2019 | 01:26 PM
  #39
freeky's Avatar
they jus starting selling e85 at the sheetz by me . so yeah im considering it .600 sound good.
Old Feb 12, 2019 | 01:58 PM
  #40
panda240ss's Avatar
i would to be honest. theres alot more benefits for it. unless u do long drive and ect then ill say do flex fuel. since its my "racecar" ill just run e85 only.
