Stock 6.0 with 7875 turbo
#41
no need in New gaskets and bolts. Just clean them off copper spray lightly and put them back on. Matt made some crazy #s on reused gaskets and bolts. Just torque them to like 70 ft lbs. If you must replace the bolts dont use part store ones, I have snapped them off doing the gm spec sequence. Matt has talked about this a lot in his videos
#43
https://www.jegs.com/i/Aeromotive/027/11569/10002/-1 will this work for 600 whp . whats this pump rated at ?
#44
it should. I have the same pump in mine.
#45
Yea true just make sure you measure with a rope the length you need! and that it can hold e85
1 single 450 CAN do e85 but i run the rather safe than sorry and do 2 450s tbh! everyones told me the same.
i dont know if i mention it on another thread but!
2 450s are like 200 bucks and 1 525 is 200$
i rather spend 200$ on fuel system which if down the road i wanna make more power the 2 450s can hold up than running lean by accident or something. OR you can do a boost a pump but i just rather do 2 pumps imo.
The following users liked this post:
Homer_Simpson (09-02-2023)
#54
#55
Back when i had stock bottomend..228r cam and pac springs just on 94 pump gas i made 630whp and 699tq around 13psi. I got greedy and tried bumping up to 15psi a few times and oddly enough the ringlands and rods bent lol.I repeated that mistake twice pushing the limits of those gen 3 stock internals on pump gas with 15psi.
Now I have a more solid setup..running out of turbo..fuel pump and duty cycle on my deka 80's
#56
ive got a 88 irocz im thinking about using the stock fuel lines an a walboro 450 fuel pump . what fuel pressure reg . would be a good choice ? im thinking about running e85 an i need the one to one boost reference .https://ls1tech.com/forums/chevrolet...88-iroc-z.html
#57
#58
my plans jus changed alittle . a 5.3 just dropped in my lap for 100 bucks gonna go with a summit stage 2 turbo cam .7875 turbo . walboro 450 fuel pump . still need advice on what fuel pressure regulater tho .
