Roots-type supercharger gurus.............
I've been told that if I spin SC'er too high on the top end which will is great....max power.......It will be spinning too fast down at the low rpms when driving normally around town.
Is that true.....?
Say use a 70mm upper and a 10% lower, it'll spin at 22,700rpm at 7,000 engine rpm. Will that drive perfectly normal at idle, cruising at 30-40-50-70 mph.
Is there any problem like this with roots-type SC'ers.....?
Thanks....
10:1 compression
Large Intercooler
I have a 408 that made over 900hp on the dyno with a 10-71 old school roots blower on E-85 at 15lbs of boost and compression is 8.5:1, Lower compression and more boost is better than more compression and less boost unless something changed that I didn't hear about?
He's not going to get those numbers with an LS3 bore and stroke or LS3 heads unless they are heavily ported but a stroker combo with good heads should get him there.
Not taking advantage of e85 fully with that compression. Old school thinking would suggest the low cr more boost is the only way to go but tech has advanced. Outside of this site many people are and have been doing high cr setups with lower boost and timing levels with great success. Mine is stock cr 10:7.1 and I’ll bump it to the 11’s eventually. 980 and 21psi sbe LS3. He can make the power with one just have to do it right.
The main reason people say otherwise is usually because they are running a turbo on the street and don't want it to be a dog off boost, Roots style superchargers don't have that problem.
Aren't you running a centri not a roots? A roots blower doesn't suffer from low end power loss with lower compression like a turbo and centrifugal supercharger does. They make boost from idle and make tons of low end torque.
That was NOT with the larger 10% lower pulley.
Another guy in South Florida made 803 RWHP with a basically stock Chevy SS engine....no mods except for the Harrop 2650 and a new cam to accommodate the blower. Ran 9.84 @ 142 mph.
Here it is at the drag track and doing highway pulls: ((just about the ugliest car possible....but it shows what the Harrop can do on the LS engine))
