Summit ls turbo cams?
The only true test....is testing. Which is why cam naming is bullshit, and all this "custom cam" nonsense is also bullshit. Without back to back testing....nobody can tell you what cam is best for any given combo.
Although keeping it simple...you'd need to be retarded to actually pick a very bad cam on an LS combo.
My Tuner says stock 2wd Chevy 5.3 trucks on his dyno usually make 240-250rwhp, so this cam picked up nearly 100hp...
The Ghost cam would be excellent in an LS3. Its design is related to our own Stage 3 SUM-8710 and Stage 4 SUM-8711 “LS3” specific cams. The main difference in those cams is different intake lobe profiles. This is to gain more piston to valve clearance with the big 2.165" intake valve.
The Ghost cam’s smaller intake duration allows the heads to be milled .030" for increased compression and torque. The negative overlap offsets the LS3’s increased chance of reversion. With all Pro LS cams, we aren’t big on late exhaust closing. This helps prevent reversion at part throttle which is where most engines often live.
An LS3 with the Ghost cam will be plenty enjoyable!
Forged iron block, 900-1000hp. I just saw that stage 4 is a max effort build cam. Id like some lope, not sure if I fall into the max effort category lol.
Is this a street car? Drag track car? Mix of both? The stage 3 and 4 will require a high stall converter, the stage 4 probably needs about a 3800 stall, I ordered a 3400 for mine and it ended up stalling at 3100 and it does pretty good with the stage 3.
My buddy did the stage 2, it doesnt have nearly the idle lope the 3 does but it seems to pull about the same and he has a stock converter. It all really depends on where in the RPM's you prefer the power at.
I would pick a 2 for you by default, in fact I kind of wish i did the stage 2 instead. I don't think the 3 makes any more power and it just pushed the power up to 5-6k range instead of 4500-5500.
from the Dyno I’ve seen, it was only a few hp difference between the stage 1, 2, and 3. Basically what it boils down to is sound and drive ability. Especially with a turbo car. So what if you gotta run 1/2 psi of boost to make up the difference between the stage 1 and 2 or 3. If you want it rowdy, get the stage 3. If you want a decent lope but note too rowdy, get the stage 2. If you don’t care if it has much lope, get the stage 1.
do note, as you go up in cam, you’ll need to go up in stall. I have a stage 1, it has very little lope in my 5.3, and drives like stock. However, it loped more in my 5.7 because I had probably at least a point more compression. The 5.3 is like 9.4 to 1 and the 5.7 was like 10.5:1.
