Pump Gas boost vs Timing Opinion
Im tuning my twin turbo 4.8 and am starting to get jittery on adding more boost. Ive read danmahs opinion of 14*/14psi being pretty successful but im unsure if he ran meth with that. Ive also read that less timing and more boost is potentially safer than high timing low boost. I want to drive this car somewhat reliably for alittle while before i turn it up. I plan on just reading the plugs after runs but its been raining its *** off and i haven't been able to.. Can i get pump gas timing/boost ratio opinions?
-gen 3 4.8 862 heads
-pac1218
-stock cam (higher compression with stock cam?)
- twin he351cw cummins turbos
Im currently at 14*/8psi. I know these turbos are made to be efficient around 21psi so im curious what direction you all would go in regards to 93 octane timing/boost.
P.S. Posting the build right now also if interested.
Thanks,
-pac1218
Thanks,
Is 14/14 with Meth and NO intercooler okay?
What about 14/14 with NO meth but with an Intercooler?
Last would be 14/14 with Meth and a Intercooler, would that be shorting the timing or boost or both?
Agree with reading the plugs, they are never wrong. Just be prepared to make a pull and shut her down quickly so you get a clean read.
Now that I think about it a bit does running meth clean the marker on the plug strap?
Spider, So you don't run an IC or meth? Wouldn't you bump a few degrees if you did?
this. This is my thought process also.
- look at the heat mark on the strap to determine too much/little timing. Halfway between the end and the curve is safe.
- look at the heat on the threads to determine if plugs are too hot.
- use the loupe to look at the porcelain for signs of detonation. Black specks are a bad sign and silver specks are aluminum! You cannot see it with the naked eye and if you can hear detonation under boost, it's probably already too late.
- only way to tell rich/lean at WOT is to carefully cut the thread off one of the plugs and look at the ring at the base of the porcelain.
PITA, but the plugs are the only things to follow for tuning YOUR setup. Like others have said, run meth and run it straight to get the octane and let the plugs tell you how much more timing you can run. DO NOT trust pump gas or windshield washer fluid, etc, etc. With pump gas you want the additional octane from the meth, especially running a small displacement 4.8L with higher cylinder pressure.
