Tuning Help needed - stumbles when boost starts
Old Apr 7, 2019 | 03:03 PM
Matt_l's Avatar
Default Tuning Help needed - stumbles when boost starts
I am just started to retune my motor after the swap to a 4l80e, and I am stuck. I am running a 5.3 motor with 4l80e basic sloppy setup. The motor runs pretty good until it starts to get any boost and then it just stumbles and wont go any higher. I had the same setup last year before I switched the trans over to a 4l80 and I did not have this problem. For that reason, I do not think it is a hardware issue. It slao does not seem to be going lean, so I was thinking it is not a misfire. Any help would be greatly appreciated. I have attached my tune and a couple logs.
Thanks,
Matt
File Type: hpl
File Type: hpl
Old Jan 10, 2020 | 06:46 PM
blacksi's Avatar
Thanks,
Matt
Did you figure it out? Do you have a vacuum based FPR?
Old Jan 15, 2020 | 06:38 PM
mightyquickz28's Avatar
Looked at one of your log files. Like you say, it got up to 102kpa with 68% throttle position and yet the timing advance is -10 (minus 10) degrees.
Knock retard at that point is zero but 'burst knock' is -5.7.
It indicates you're running a 2 bar. So this tune was running great till you installed the 4L80E?
Thanks,
Matt
