LS3 Throttle Response - Stock TB or 102?
Was the difference really noticed or minor?
Off boost part throttle?
Tip in vs Mash it
I currently run a 102 billet TB (DBW) with piping from the intercooler that runs from 2.5" outlets to 4" into the TB. I was wondering about going going down to a stock TB to pick up response. I doubt there would be any power loss as I'm not pushing hard and won't see north of 1000rw. If the difference is not great I'll stick with what I have.
Looking to build a forged blueprinted LS3 with stock stroke but run Darton MID sleeves and take it to 4.125" bores, add studs top and bottom and build a durable 388 that I can lean on lap after lap and day after day. I can't afford ITBs so thought I'd stick with the stock LS3 intake and wondering if TB is ok being so big.
At same time as forging engine I'll downsize exhaust to turbos to 2 x 2.25" inlets and coat and wrap the entire thing to retain heat and build velocity. Hopefully that will drop boost threshold 500rpm and add a little more hp/psi over the LT headers.
Dale ran the little RX3 to around 2000hp with a standard 90mm TB.....mayhbe a little more. So there is simply no need or benefit from larger on a boosted build like that.
102 is just pointless really.
Agreed re mid mounted turbos - I will be greatly increasing the velocity and heat in the exhaust to fix that best I can - I think we'll get close to a front mount with some help from heat insulation and downsizing smoothly.to reduce turbulence. From manifold/collector to turbos will be only 2 bends of any consequence - which I can make long and smooth.
Some may think the wet liner is better for cooling etc. I'd say in reality there is no difference.
And where possible...I'd always try and avoid aftermarket liners in the first place. They seem to be hit or miss to get them right...and when yours goes wrong, it's a massive **** up.
Even the likes of an LS9 supercharged vehicle from the factory, I'm sure they've done more extensive and abusive testing than any road racer ever would prior to the vehicle ever getting released.
it seems sleeves in general are no job...for many machinists. To date....I've only ever had bad experiences with any re-sleeved blocks, of any manufacturer. Hence my first choice will always be a factory block, until I see real evidence to the contrary !
Factory OEM blocks have to be economic, and they do not have to hold 1000hp. I talk to a few top shelf race engine builders - not one of them rate the LS blocks for serious power. Compared to the serious aftermarket blocks they use, the amount of shift and long line of breakages they've seen - they just won't use them anymore. So I feel a bit alone trying to make it work... when everyone is saying to me "**** it go buy an RHS and be done with it". That's another 3k. Katech uses RHS on all its top builds, but that does give them a lot more leeway. Before I sleeve - I will be talking to Katech and RED and Texas and anyone else that has 1st hand experience.
Without issues . They freshened it up and put it in the red vette he has now . Only change is they
Machined it for 1/2 studs .
