meth injection feed line?
Old Apr 11, 2019 | 01:06 PM
trboman's Avatar
Default meth injection feed line?
Do I really need the AEM or Snow methanol injection 1/4 feed line? or is it the same as the pneumatic 1/4" air line with a different name stamped on the side? I will be running washer fluid through it.
Old Apr 11, 2019 | 02:36 PM
truckdoug's Avatar
i just use J844 sae 1/4 air line never had a problem.
Old Apr 11, 2019 | 03:54 PM
imma_stocker's Avatar
1/4 hard nylon line on my kit with push-lock connections. No issues running mix or straight methanol for a few years and lots of street miles.
Old Apr 11, 2019 | 05:19 PM
trboman's Avatar
thanks, I am going to use the air line I already have.
Old Apr 15, 2019 | 10:01 AM
jimmyg's Avatar
My snow kit has the plastic lines so I was worried about straight meth. But then I was thinking , they use plastic fuel lines all the time, so what's the difference?
Old Apr 15, 2019 | 11:53 AM
Plastic lines with 100% methanol through mine. Pushed a full drum through without issues from the lines. These plastic lines don't react with alcohol so the only thing to check are look for dried out sections from age/heat exposure and verify connections don't leak. Other than that the pumps usually fail before lines due to seals leaking, especially if the pump isn't 100% methanol compatible.
