Anyone seen the new Engine Masters with meth?
Old May 2, 2019 | 12:25 PM
  #41
stevieturbo's Avatar
Originally Posted by BCNUL8R
In that case is it possible to mix methanol with pump gas at the desired percentage and just run it through your regular fuel system/injectors. I know running methanol is an issue with most fuel systems not capable of handling it, but is there a percentage where you could get positive results without being an issue for a fuel system capable of handling e85? Say pump gas with a 25 percent mix of methanol? Just curious.
Using around 20% methanol in the fuel tank is pretty common here in the UK. It helps pump fuel, and doesnt push the fuel system too hard in terms of extra flow needed.
but obviously as it will be tuned to expect this at all times....you need to run that same mix at all times.
Old May 2, 2019 | 01:00 PM
  #42
goloco's Avatar
Their test seems wanting, to say the least.
I found this test, seems to be a better controlled test...
https://www.hotrod.com/articles/dyno...tion-turbo-ls/
Full range gains with no tune change, just add the meth/water spray and off they went.
  #43
BCNUL8R's Avatar
You guys use a stoich of about 13 for 20 percent meth mixed with pump? I use 10.7 with E70 or 11.8 with E50 and works pretty well with no other changes.
Old May 8, 2019 | 12:52 PM
  #44
Kfxguy's Avatar
I wonder if they had a progressive controller or just sprayed it with no control down low. That would definitely kill power in the lower and mid range I would think!
