Crazy idea? use boost to inject meth?
Old May 10, 2019 | 11:25 AM
Kfxguy's Avatar
Default Crazy idea? use boost to inject meth?
Was just thinking. For a super uncomplicated added boost in cooling, why not get a sealed tank, at the top run a boost pressurized line from the turbo and then the outlet of the tank run to a nozzle pre turbo. yea it make not inject as much as a pump, but use a little bigger nozzle but only use this as a supplement to help cooling...not rely on it. would be super easy and cheap. dumb idea?
Old May 10, 2019 | 11:43 AM
Black_Sunshine_99's Avatar
Well I think a typical meth injection pump runs around 300 psi and you'd only be getting 20-30 using the turbo so the atomization of the spray may suffer?
Old May 10, 2019 | 12:08 PM
Kfxguy's Avatar
True. I didn’t realize they used that much pressure especially when I’ve been considering doing it the homemade way using a washer pump. I didn’t think a washer pump put out much pressure. I’m gonna experiment with nozzles this weekend on the bench and see how much flow and atomization I can get. I was only considering this for now as I figured something better than nothing until I can afford a real kit.
Old May 10, 2019 | 02:50 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
Did a little research on this myself: https://gbodyforum.com/threads/copo-....61336/page-44
Old May 10, 2019 | 10:53 PM
Kfxguy's Avatar
Well I guess it won’t hurt to try it
Old May 11, 2019 | 03:01 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Congratulations, you just invented a carburetor. Unfortunately, your design does not sound like it would work as good as you would like without additional one way check valves. While you do have a workable idea, I do not believe it will be as simple as you would like. Don't let it stop you from experimenting.
Old May 12, 2019 | 08:05 AM
stevieturbo's Avatar
It's been done before, and was in threads I posted links with previously. Most important part is a low pressure atomising nozzle.
And no, as long as the water tank is lower than the nozzle so it cannot gravity drain no check valves are necessary
Old May 12, 2019 | 02:42 PM
Also: https://www.hemmings.com/blog/2013/0...obile-jetfire/
http://www.speedhunters.com/2015/06/...jetfire-turbo/
https://www.hotrod.com/articles/olds...linois-garage/
Old May 13, 2019 | 01:13 AM
gametech's Avatar
I would not be concerned about gravity drain, but rather using fluid from the air across the nozzle in the same manner as a paint gun or carburetor works.
Old May 13, 2019 | 05:44 AM
Ben.'s Avatar
Has been done quite successfully many times. As stevie mentioned, the key is to get a good atomizing nozzle that works at low pressures.
It's probably most atributed to a rotary guy who goes by "rice racing". By all accounts, he's a complete ******* of a bloke who sells over priced kits, but he does have some good info out there.
Old May 13, 2019 | 07:51 AM
TrendSetter's Avatar
an old friend had a setup i thought it was called mr freeze, but it used boost to pressurize a tank that sprayed at the inlet of the centri blower. there was concern that the fluid hitting such a fast moving blade would eventually erode it.
Old May 13, 2019 | 11:42 AM
zero concern with the correct nozzle.
Old May 13, 2019 | 12:59 PM
Kfxguy's Avatar
Thats what ive been reading. no one has actually experienced blade erosion. I mean they hey ran draw through carb turbos for years with no issues. Myth? I think so. And even if it does, by the time that happens, it'll be time to replace or rebuild this china turbo anyways lol. Blade erosion is the least of my worries.
Old May 13, 2019 | 03:05 PM
If you want to worry about blade erosion...run no filter or a turbo guard..then you;ll get blade erosion lol.
Old May 15, 2019 | 12:09 AM
2kgtp's Avatar
I did this a while back on one of my supercharged 3800’s. It worked but it was very inconsistent and overall not worth it. My $.02
Old May 15, 2019 | 12:28 AM
Kfxguy's Avatar
Can you elaborate on what you did and how it was inconsistent? I’m curious.
