Procharger guys - ATI damper assembly ??? See Pics
Am I understanding this correctly, Assembling the damper, I have 3 medium length bolts and 3 long bolts. Do The 3 medium length bolts hold the outter shell to the inner hub? then the 3 longer bolts hold the CBR pulley to the damper? Is this correct?
I cant remember exactly but i think the 3 longer ones were for holding the AC pulley on and the shorter ones were for the outer to inner hub connection. The CBR (or Procharger pulley) was mounted with short bolts.
The three bolts in pic should slide all the way thru the front dampner portion. Thats why i think you need to rotate.
I have the same exact setup and mine had zero issues. I thought I had pics of me doing mine but I can't find them. I can try take a pic but the blower pulley is mounted.
Bob @ Brute speed care to chime in? Maybe pm or email him. He responds VERY quickly and after hours support is awesome. Best customer service ever IMO.
Does your AC pulley have (3) 3/8" tapped holes and (3) 5/16" tapped holes?? .....(pretty sure they are 5/16)
