new nova build thread.
Old Aug 17, 2019 | 02:24 PM
  #41
truckdoug's Avatar
^ thats a quality intercooler for the beans
Old Aug 17, 2019 | 03:38 PM
  #42
17outs's Avatar
But requires trimming right? Its a 3.5 inch thick unit?
Old Aug 17, 2019 | 04:17 PM
  #43
yenkomike's Avatar
I went with a mishimoto unit from summit. rated for 1250 cfm I believe. 3" is all I can run with a stock hood latch. looked at all the universal units and the one I bought was rated at better flow than the other cheaper coolers. we'll see.
Old Aug 17, 2019 | 04:23 PM
  #44
yenkomike's Avatar
there website says 1250 cfm rated to well over 850 hp.
Old Aug 17, 2019 | 05:34 PM
  #45
17outs's Avatar
This one?
https://www.summitracing.com/parts/mio-mmint-umb/
Old Aug 17, 2019 | 07:06 PM
  #46
3 window's Avatar
Here’s what I had to trim.
Trim top of the grill to follow the contour of the upper tank and cold side tube.
Knock out the bottom rows of vertical bars on the grill
Had I moved it down, I could’ve used the factory latch, but I didn’t want it hanging down too low. Also a small area of the lower right side of the core support was cut back. That allowed the cold side tube from the turbo to stay tucked up real tight also.
Old Aug 17, 2019 | 07:16 PM
  #47
yenkomike's Avatar
yes that is the exact one. have not seen it yet but I see this brand used a lot in d-max builds. flows better than the cheap universals I was looking at.
Old Aug 19, 2019 | 05:42 PM
  #48
yenkomike's Avatar
got my intercooler and radiator in today. both look very nicely built. I did also get my rear disc brakes installed over the weekend and started the long process of building the wire harness
Old Sep 1, 2019 | 09:09 AM
  #49
yenkomike's Avatar
well I have been getting stuff done but everywhere I look it needs something finished. here are a few pics. hotside done will fit power steering .
Old Sep 1, 2019 | 09:39 AM
  #50
truckdoug's Avatar
nice. imo thats the best way to set up for a single.
you're gonna run the MS3 again right?
Old Sep 1, 2019 | 09:46 AM
  #51
yenkomike's Avatar
yes a gold box. im going to work on the fuel system next. aem 400 and 210 bosch injectors for now. will add a second aem by spring.if I get it running and driving this fall and the bugs worked out at about 10 lbs boost ill be happy. but we will see.
Old Sep 1, 2019 | 09:50 AM
  #52
truckdoug's Avatar
nice. I have 2 450's and thinking about stepping down to a single hellcat pump at my power level
i'm new to the onboard boost controller. do you use air/co2 or compressor side pressure to operate your gates?
Old Sep 1, 2019 | 12:01 PM
  #53
yenkomike's Avatar
I have always used boost and a manual controller and let it build as fast as it can. but I found that with the devided 2 1/4 hotside with the t6 1.32 it will get to 20 psi in less than a second if leaving with a 2 step. and now with my 2.48 first gear in a 400 turbo it might be to fast to hook. this one im going to start off manual and low boost but set it up for boost control using the gold box. going to keep it super simple to start just a good tune and 10# and get it running good like that then start adding stuff. and turning it up of course. my last nova ran 9.01 at 150 on 18 lbs boost and I want this one to run that number on less boost. it should as I have upgraded every part as I go. but the blue car ran very well.lol
Old Sep 1, 2019 | 03:09 PM
  #54
truckdoug's Avatar
yeah the last car moved out pretty dang good.
I am really impressed with the holley PID boost control, I would think the MS3 could be configured almost identically.
it's so cool to enter 15psi into a chart and have the car actually make 15psi
Old Sep 2, 2019 | 09:22 AM
  #55
forcd ind's Avatar
I think thats the IC'er I used in my truck, although I have the unpainted one-seems to do alright,
but no passes yet.
Old Sep 2, 2019 | 02:03 PM
  #56
yenkomike's Avatar
it looks well made . I was surprised.
Old Sep 3, 2019 | 08:54 AM
  #57
17outs's Avatar
May I ask what the gold box is?
Old Sep 3, 2019 | 09:39 AM
  #58
yenkomike's Avatar
gold box is megasquirt 3 efi system and harness sold thru efisource.com. like the holley terminater x. system.
Old Sep 8, 2019 | 04:19 PM
  #59
yenkomike's Avatar
got some work done. not as fast as I wanted. but I got my down pipe made . all the fuel lines made and finished and some under hood work. still needs about 10 little things done and it should run. but im sure i'll find more little stuff. lol.
Old Sep 10, 2019 | 09:57 PM
  #60
17outs's Avatar
Great pics. Curious if that intercooler will stand the temps. Usually the bigger 3.5" ones are rated at higher hp. Seems to fit pretty good! No mods to hood latch.
