BOV ?'s
Old Aug 4, 2019 | 08:30 PM
woodee's Avatar
Default BOV ?'s
OK, I'm slowly putting together my first turbo build, how important or necessary is a blow off valve? I really don't like the ricer woosh sound, but if I need one, I will work one in.
Old Aug 4, 2019 | 09:58 PM
Game ova's Avatar
GN'S and others didn't have them, and did fine. But it's debatable as to if not having one is hard on the compressor. Personally, I'd do it, as it isn't exactly big money.
Old Aug 4, 2019 | 10:31 PM
Lsx Rubi's Avatar
I just finished a build on gen4 Alu 5.3/4l80e with s475 and I don't plan on running one . Driving around town I barely ever hear compressor surge if the boost stay below 4-5 lbs . I plan to daily drive it, will see how the turbo holds up. You can also recirculate it to avoid the noise also they sell quite ones as well that don't sound ricey.
Old Aug 5, 2019 | 12:12 AM
ls1_e36's Avatar
You can always recirculate the blow off if you would like!
Old Aug 5, 2019 | 08:30 AM
Z32_5.3's Avatar
This is prob your best bet. You can get a BOV that has a tube output. Route that back into your intake tube pre boost pipes.
point of BOV is to release positive pressure from tubes so the pressure doesn’t smack your TB and break it, as well as having all that pressure go back towards your turbo. Kinda no point in NOT running one.
Old Aug 5, 2019 | 07:05 PM
kingtal0n's Avatar
Yep you want one.
Put it as close to the compressor as possible.
Never after an intercooler.
A good re-circulation will re-capture some of the kinetic energy of compressor input and is highly recommended, it may improve response (higher initial shaft rpm)
Old Aug 5, 2019 | 09:56 PM
woodee's Avatar
OK, sounds like I should use one. When you recirculate, do you direct it back into the hot side before the turbo?
Old Aug 5, 2019 | 10:55 PM
kingtal0n's Avatar
Yes take some time to look at factory turbocharged vehicles. Like nissan sr20det, toyota 2jz-gte and mitsubishi 4g63 style engines.
Near all factory turbo cars use recirculation to appease the maf sensor and it just happens to also help with the shaft speed if done right.
The bypass simply routes back into the turbo inlet, right after the air filter before the compressor wheel.
Old Aug 6, 2019 | 07:51 AM
JoeNova's Avatar
Restricted User
Its not easy to find a BOV that can recirculate enough CFM for a turbo V8 setup.
If you have an anti-surge compressor housing and an auto trans, you can do without one.
Old Aug 6, 2019 | 10:06 AM
kingtal0n's Avatar
You can always 'do without one' the negative consequences are not tangible immediately
I have an auto and anti-surge housing and still heard a significant amount of surge just driving around below 3psi.
I would never run a turbo I cared about without a bypass and high quality paper air filter.
