BOS is at the track.......
Old Jul 14, 2004 | 10:58 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I missed you going to the track... Dang!!!!
Congrats, you have a baseline after over a year!
Old Jul 14, 2004 | 11:35 AM
CHRISPY's Avatar
Cam should pick up 40RWHP easily I think
What other changes are you planning?
Old Jul 14, 2004 | 11:45 AM
ChevyNo1's Avatar
Originally Posted by NA$TY-TA
In his sig Chris.....
Dyno #'s: 462rwhp & 522rwtq w/10psi @5900rpms
Good Job BOS........
Kyle
Very nice times!! Glad to see the 370 is workin' out for ya!
I have a question though . . . and I know that the online HP calculators are not perfectly accurate . . . but when I plug in 3650 and 11.09, the calcs say that you need approximately 529rwhp to do that . . . and if I plug in 3650 and 462rwhp, it says you can run a 11.57 @ 118. Am I missing something here?
- Dug
Old Jul 14, 2004 | 11:50 AM
LS1Tech Co-Founder
He is 469rwhp thru an unlocked T400 setup. He would be easily over 500rwhp thru an M6 trans.
I wonder how much boost he's making, I bet Bos will pick up a lot more as he tweaks his setup.
Old Jul 14, 2004 | 11:54 AM
ChevyNo1's Avatar
Thanks for clearing that up John. I'm 'a used to the M6 way of thinking
- Dug
Old Jul 14, 2004 | 12:11 PM
IRVINEWS6's Avatar
Why is BOSS's rwtq higher than his rwhp? I thought superchargers always produce more hp than tq. I know turbos and nos produce higher tq than hp numbers.
Old Jul 14, 2004 | 01:42 PM
BIGBOS's Avatar
Probably due to the high flash of the converter, its always been like that.......
I'm making 10-11 psi consistently.......
Next up is the Griffin Intercooler, which should be here in a week or so.....I'm going to do the 3.2" blower pulley with the 51.5" belt along with that......that should give me a solid pickup, at that point I will be out of cash, and will have to scrap some checks to get a new shock and the swaybar deal fixed in the back........the battery is also getting relocated to the rear to clear for the FMIC piping.......the front bumper support is getting removed, along w/the windshield washer fluid stuff.....so that SHOULD make it slightly lighter up front....I'm still deciding on whether or not I should ditch the HVAC and what not.....
PSJ, thats the first baseline I've got since october 2002 I was a little upset when my car was 60' worse than it did on motor 2 years ago, but the last 2 passes I beat it....
Old Jul 14, 2004 | 05:12 PM
The Juggernaut's Avatar
Are you looking for trouble @ RSD?
I make trouble.
Hi Brian
Old Jul 14, 2004 | 05:47 PM
kp's Avatar
kp
never use ET to calculate anything except margin of victory 3650lbs and 121 mph is around 440rwhp. The 462 was SAE corrected so if it was hot day when he ran it will be a lower number so he is right in line with the dyno numbers..
Congrats for getting it down the track, must be fun after so long a wait.
Old Jul 14, 2004 | 05:48 PM
Got Me SOM's Avatar
The question is are you happy with your runs? What was the temp outside and the humidity when you ran? congrats
Old Jul 14, 2004 | 07:38 PM
BIGBOS's Avatar
When I got there it was about 90 out with 90% humidity, I was soaking wet just taking stuff out of the car, like the passanger seat, etc.......
I would of liked to get a 10.9 before I got the boot, but it didn't happen, I'll be doing more track testing next month......and then october will be my month to shine
Old Jul 14, 2004 | 09:02 PM
  #32
BlwnTA's Avatar
7 Second Club
Awesome.....looks like SDCE is the solution. I'm sure in time they'll refine it to handle even more. Looking forward to getting my set-up just so I can the car tuned for starters. Congrats again...looking forward to seeing some 10's from you guys.
Mark
Old Jul 15, 2004 | 02:14 AM
  #33
BIGBOS's Avatar
SD stuff is for sure the way to go.....
I'll be trying the 3.2" blower pulley and the 51.5" belt soon......that should bump me another 2-3psi........Hopefully
Old Jul 15, 2004 | 11:48 AM
  #34
LS1Tech Co-Founder
Yah I'm sure that you have a 10.x in the car now but once you upgrade those tiny ATI intercoolers that will help.
Old Jul 15, 2004 | 01:13 PM
  #35
NA$TY-TA's Avatar
My TQ has always been higher then my HP...... Even when i was N/A.
Kyle
Old Jul 15, 2004 | 03:17 PM
  #36
BIGBOS's Avatar
Yea, I figure if I would of had the chance to make about 5 more runs I could of squeezed a 10.7 probably.......
I couldn't adjust the right rear shock so it was squirly on that side.......
Old Jul 16, 2004 | 04:59 PM
  #37
Holes02's Avatar
Bos, I was talking to Big Bill when you were in line for one of your passes and he mentioned to me what the deal was with your RR shock and BMR sway bar.
They way it was explained, it seemed like the BMR seay bar you had Speed Inc. put on, shifted over and was jammed up against the RR shock dial (?), this, along with the subsequent leak from the same shock, was the reason you couldn't "dial in" your suspension??? If that's the case, and the BMR sway bar that Tom and Larry put in for you DID in fact, shift over and hit the shock, wouldn't it be safe to say that the swaybar, or inproper installation of the swaybar may have caused the leak in the rear shock? If so, I would assume Tom and/or Larry would be more than willing to work with you on getting that taken care of...Not to say they installed it wrong, but your car was in there for a long time, getting a LOT of work done, maybe they missed something small????
Either way, great numbers, good to see you back out there again. Definate improvement over the cog setup as it seems. Now get that monster cam and big FMIC in there!
Old Jul 17, 2004 | 02:17 AM
  #38
BIGBOS's Avatar
Yea, I will end up using my stock swaybar as long as I can.....I'll eventually get a replacement.....I just need to figure out why it jumped to the right so much.....
Old Jul 17, 2004 | 12:28 PM
  #39
NA$TY-TA's Avatar
BOS,
Do you have a ADJ PHR????? if so that could be it....... i had to recenter my rear a few times with mine.......
Kyle
Old Jul 17, 2004 | 08:51 PM
  #40
BIGBOS's Avatar
No I don't have one of those, the sway bar and that are the only stock suspension things left
