Metal in the oil follow up
Old Oct 4, 2019 | 04:36 PM
RonSSNova's Avatar
Default Metal in the oil follow up
Stewed over this all summer, missed the whole season, raced my Vette.
Dumped the oil and filter a couple of times then finally took it for a long drive, thinking, it might be ok.
Well, things don't fix themselves so pulled it and took it all apart.
Hard to do post mortem!
Rear main obviously had a chunk of metal go through it. Front main as well, but not so bad.
From the mains the rods get fed, and 3 rod bearings showed debris.
Nothing on the verge of failure, just pissed off.
I have to admit, I believe this was my fault. Didn't clean **** good enough. I did wash the block at work, but it's hardly a clean wash machine. In fact it's gross.
I did hose it out, and blew it out, but no matter.
So my belief is that I left metal in the oil passages.
Thrust btw looked excellent! King bearings and I did a small mod to feed that surface with pressurized oil.
Another source of metal.....the oil pump. Was clear the oil pump drive was hitting the oil pump housing. Machining itself.
I did not do the feeler gauge method of centering the pump.
So, can this metal get by the filter? I plugged the bypass in the pan. But filters bypass, and with the popcorn fart filters we run, you bet.
I believe I'll upgrade to a Moroso pan that accepts a real f'n oil filter with no internal bypass.
So more bearings. The new crank needs polished. It's "groovy" now.
And I might just let the machine shop assemble the short block. I can't keep this clean enough in my garage or basement.
Last laugh? The oil pump pickup was full of cat hair...…..
My disclosure.
Ron
Old Oct 4, 2019 | 05:51 PM
yenkomike's Avatar
no matter how clean you get it . if you cut the first filter open there is crap in it. with a new engine I run cheap tractor supply oil and change the hell out of it. I hate to even pull the valve covers off. as it bugs me and i'll run it a half hour and change the oil. I might be ocd about it but they seem to live. sound like you got to it early . and it is an easy fix.
Old Oct 4, 2019 | 06:17 PM
forcd ind's Avatar
I was wondering how this came out when you first said there was a problem.
Cat hair, sounds like half the rags around my house, if you dont bag them the cats will
find them and sleep on them, lol.
Old Oct 4, 2019 | 08:55 PM
Bad Apache's Avatar
I was really itching to ask how your engine problem played out. Glad it was all relatively simple! Now I can't wait till spring when you start whooping on it and find the next weak link. It's nice having you do all the research for me, lol.
Old Oct 4, 2019 | 09:56 PM
truckdoug's Avatar
damn and I thought I had it bad with my dog eating my weed brownie off the coffee table!
