7875 vs gen 2 7875 size difference?
Old Oct 17, 2019 | 09:36 AM
Kfxguy's Avatar
Default 7875 vs gen 2 7875 size difference?
Trying to get a visual on the size difference between the regular vsr 7875 and the new gen 2 7875. My car is kinda tight for space but I might be able to get it to fit. If someone has already posted a pic, I cant find it, please point me in the right direction. Thx
Old Oct 17, 2019 | 10:55 AM
Lbzdmax07's Avatar
I'm not sure on the size difference from a huron 7875 and a vs gen 1 7875 but the gen 2 is practically the same size as the Huron. Turbine housing just slightly larger to be expected.
Old Oct 17, 2019 | 12:28 PM
forcd ind's Avatar
I thought the gen 2 went to a 4" exhaust, Matt might know since I think he has used both.
Old Oct 17, 2019 | 12:32 PM
Kfxguy's Avatar
LOOKS LIKE THE OUTLET ON THE COMPRESSOR SIDE OF THE HURON IS 3" whereas the outlet on my 7875 is 2.5"
you havwe a pic of the exhuast side on the gen 2 vs the regular one?
thx btw
Old Oct 17, 2019 | 12:34 PM
SLOW SEDAN's Avatar
It is a 4" turbine outlet, but you can slap a 4-3.5 or 4-3" reducer on it to connect to your piping without too much impact. Guys have made 800+ on a 3" downpipe and maxed out the Precision 7675 on a 3.5" downpipe closer to 900 so just depends what your goals are.
Besides the turbine being a little girthier I don't see much overall size difference.
Kfxguy's Avatar
it did
Old Oct 17, 2019 | 12:37 PM
Kfxguy's Avatar
o and most important....is it taller (like it sits in the above pic)?
Old Oct 17, 2019 | 01:12 PM
Lbzdmax07's Avatar
Height appears to be the exact same. It bolted straight in. Only thing I done was weld a 4" flange to my exhaust. I didn't realize the original 7875 had a smaller compressor outlet
Old Oct 17, 2019 | 01:16 PM
Kfxguy's Avatar
HMMMMM......I might sell my billet 7875 and go to this......
Old Oct 18, 2019 | 09:12 AM
transam69230's Avatar
Does VSR release lbs/per min for their turbos ?
Old Oct 18, 2019 | 10:17 AM
SLOW SEDAN's Avatar
Don't think I've seen a lb/hr for Precision or the chang's, generally only Garrett and Borg.
Old Oct 18, 2019 | 10:18 AM
Kfxguy's Avatar
All i'm worried about is the housepower.
Old Oct 18, 2019 | 10:20 AM
SLOW SEDAN's Avatar
At 8psi? Get turnt! **** doesn't even wakeup until 15 lol
Old Oct 18, 2019 | 10:36 AM
Lbzdmax07's Avatar
The gen2 makes about zero turbo noise. I figured I'd mention that because that's a big deal to some. If you have the sleeper theme going it will be perfect
Old Oct 18, 2019 | 10:49 AM
Kfxguy's Avatar
I’m at 13-14 currently.
Old Oct 18, 2019 | 10:50 AM
Kfxguy's Avatar
O. Damn. I want it to make noise. Crap.
Old Oct 18, 2019 | 04:28 PM
Mavn's Avatar
"I MAID THEESE"
Ummm this is the most false thing I've ever heard the gen 2 is LOUD AS FU*K 🤣🤣
Old Oct 18, 2019 | 09:56 PM
Lbzdmax07's Avatar
In comparison to the Huron 7875, its silent. I have a bumper exit which may affect it
Old Oct 19, 2019 | 08:29 AM
freeky's Avatar
what rpm is full boost in a 5.3 with a summit stage 2 turbo cam
Old Oct 19, 2019 | 01:20 PM
Kfxguy's Avatar
Originally Posted by freeky
what rpm 13 full boost in a 5.3 with a summit stage 2 turbo cam
English please.
