Turbo bottom end
Depending on the level of "junk" the 5.3 is and your budget, boring to a 5.7 bore would be beneficial for your goals. The "no replacement for displacement" theory. The Summit Pro LS 5.7 rotating assemblies with dished pistons can be found at this link.
When it comes time to bore the 5.3, you have 3 options.
1. Buy another 5.3
2. Buy a 6.0.
3. Coffee table.
I don't own the V, I just help with ideas and fingerbang the keyboard on it while my friend drives the **** out of it. Summit Stage 4 cam was one of the ideas and it seems to work well. Engine in that car is a simple build, but has one of the largest S400 turbos on it and we have to knock first gear down a couple hundred hp to get it to stay on track. We basically have everything fighting us on that car, heavy weight, manual trans, crappy IRS, limited V1 parts availability, but we are still getting it done!
I've had an 8 sec 5.3L turbo G8 in the past and recently swapped a 5.3L into a C6 because I got sick of heavy cars. I'm using your cam and springs in the C6 without any complaints so far, spools up quicker then most people expect and that suspension seems to work a lot better then the family car stuff, not exactly shocking being 1000lbs lighter. I have another spare engine on the stand so I've been eyeing your new parts all around. I like what you are bringing to market so far!
would you recommend these for 900whp range? Is the crank needed? Comes with setup for 2k I’m not complaining, just asking.
Then again, I'm at ~24 PSI at 7400 RPM on stock gen 3 stuff and I'm going for 29 PSI and 7600/7800 so its bound to break eventually. Ohio winters and a car with no body will stall me until probably March.
A 6.0 with gen 4 pistons/rods will do 900 wheel. Your GT35s are T4 so they will handle a 6.0 without things getting too weird.
If you can't run anything larger than 3" downpipes, you'll either need to run cutouts with full exhaust or open dumps if you want to keep the backpressure ratio happy.
You think my current turbos could keep up to a 6.0 block? Or you were saying t4 housing should be ok for many options a 6.0 would require?
honestly at the end of next year if nissan trans, turbos, clutch, rods last next summer, I plan to go th400 with the 900whp range. At that point maybe I’ll just go exhaust out the fender. Open downpipe now is not to bad considering I don’t have interior at all in car yet. Also they go right to under dash area so they prob at its loudest point right now.
either way the goal is 100% to get above 700 and at that power, run auto trans. Use this next summer as learning curve with 3200lb car and 5-600hp/tq
