Adding LSA Super to 09' Colorado V8 E67
Old Nov 21, 2019 | 03:05 PM
FormulaBoat's Avatar
Default Adding LSA Super to 09' Colorado V8 E67
Hi all. Somewhat of a rare situation, I'm looking at what is required to add an LSA supercharger to my 2009 Colorado V8 w/E67. I "think" I have to stay with the stock Colorado E67 OS, because the Colorado E67 uses both CAN and serial data. So with that said, will there be enough functionality to install and run the supercharger correctly with just the HP-Tuners selectivity? When I read my stock ECM file, there are options to simply enable the supercharger via a drop down tab, but would the ECM be able to adapt and utilized the additional input sensors or whatnot? I think there is a second air temp sensor that needs to be added, change the MAP to larger range, etc?
Appreciate any guidance from those which have done, this situation is slightly unique. I have posted this same Q over on the HPT forum as well. Thanks.
Old Nov 21, 2019 | 09:38 PM
1FastBrick's Avatar
Ask these guys on performancetrucks .net
https://www.performancetrucks.net/fo...ke-2-a-551978/
https://www.performancetrucks.net/fo...vs2300-556302/
Old Nov 22, 2019 | 07:07 AM
joyridin''s Avatar
This should not be an issue. All you really have to do is convert it to a 3 bar set-up, and adjust the fuel/timing/ etc. Do a search on here as there are plenty of posts. If you have HPTuners, go into their repository and find a stock tune for a newer model CTS-V or ZR Camaro and copy the tune into your computer.
Old Nov 22, 2019 | 07:52 AM
Thanks for the leads and advice, will study them deeply.
