summit stage 2 turbo cam
Old May 9, 2019 | 09:53 PM
freeky's Avatar
Default summit stage 2 turbo cam
.Stage 2 LS Turbo Cam. 226/230 113+4, .600/.575 Lift i ordered one this morning for my lm7 5.3 . im gonna use a 7875 turbo .anybody else running this combo ? what size pushrods did you use ? what boost you running ? ets an mph an dyno numbers ?
Old May 10, 2019 | 05:08 AM
forcd ind's Avatar
I have one, just got it running so not much data-it did degree in on the money though.
I have a 6.0, LS3 heads, ended up with 7.350 PR's, but every combo is diff.
I have the 83/75 turbo
Vac is around 13 at idle.
Old May 10, 2019 | 05:32 AM
freeky's Avatar
thanks . it will be july or aug before i get mine running
post a video of it idling when you get a chance
Old May 11, 2019 | 08:16 PM
HeavyMetl's Avatar
I've got that grind in a 4.8, naturally aspirated for now. It idles tame and doesn't have much chop at all. Pulls clean to 7300 on motor. I'll take video and upload next week when I'm off work.
Old May 13, 2019 | 11:38 AM
freeky's Avatar
THANKS id really like to hear a video of it idling . it will be end of july mid august before mines in the car an running .
Old May 22, 2019 | 11:00 AM
FowlerMotorsports's Avatar
Any videos on this cam @ idle?
Old May 24, 2019 | 03:22 AM
freeky's Avatar
my engine wont be running till july or august
Old May 24, 2019 | 06:18 AM
SE-R Spec's Avatar
Old May 26, 2019 | 06:42 AM
freeky's Avatar
id like to hear one from the back of the car .
Old May 29, 2019 | 12:21 AM
freeky's Avatar
im wondering what lifters you guys are using with this cam . ls7 or stock ? are you changing them for the cam swap ?
Old Jun 3, 2019 | 03:25 PM
HeavyMetl's Avatar
Here's the idle clip of the Stage 2 in a 4.8.
Old Jun 4, 2019 | 06:35 AM
freeky's Avatar
thanks for the video clip . i like it
Old Jun 7, 2019 | 04:57 AM
freeky's Avatar
i just ordered this : https://www.ebay.com/itm/GT45-V-Band...947b%7Ciid%3A1
Old Jun 19, 2019 | 12:54 PM
9outofs10's Avatar
I'm running the summit stage 2 in my 5.3 as well. Here's a sound clip
Old Jun 20, 2019 | 03:24 AM
freeky's Avatar
9outofs10what else you got done ? . are you gonna run a turbo ? if so which one ?
Old Jun 20, 2019 | 06:21 AM
9outofs10's Avatar
If you look closely in the video, there's a gt4294 peaking out. I have a build thread on here.
Old Jun 20, 2019 | 01:07 PM
freeky's Avatar
got a link to the build thread ? hows that spool ?
Old Aug 7, 2019 | 07:21 PM
JoshuaGrooms83's Avatar
Im really eyeballing one of these stage 2 turbo cams for my ls1. Got a GT45 hanging it now, but considering a cam for later
Old Aug 8, 2019 | 12:18 PM
wes302's Avatar
Old Aug 27, 2019 | 04:57 AM
freeky's Avatar
What size push rods everybody using
