Post turbo flex pipe?
Old Nov 22, 2019 | 07:29 PM
customblackbird's Avatar
Default Post turbo flex pipe?
Got a 5.3 with a billet vs gen 1 78/75. 3” down pipe that I’m redoing and fabbing connection to the 3” catback after the cutout. My question is if the motor has solid mounts, turbo is mounted to the car and the exhaust is floating at the stock rear attachment rubber exhaust hanger (3rd gen firebird) do I need a flex pipe between the down pipe and the rest of the exhaust? Or can it just be solid mounted and left alone? I’m not sure about the exhaust growing as it gets hot and want to do it right this time around and help with any vibrations I might have been getting. Basically if the catback is supported by rubber exhaust hangers does it need a flexpipe between the turbo/down pipe and the rest of the exhaust?
Old Nov 23, 2019 | 12:09 PM
jordoza's Avatar
This is a touchy subject around here but my opinion before turbo yes you need a flex after no you dont.
Old Nov 23, 2019 | 12:35 PM
gotcha. Thanks. Hoping to Finish it up today.
Old Nov 23, 2019 | 04:25 PM
stevieturbo's Avatar
With the engine bolted solid and the main exhaust hanging, I wouldnt be overly concerned about a flex.
Old Nov 23, 2019 | 07:11 PM
thats what I thought. I ended up using one only to help with lining up and removal of the sections. It’s a decent one with the liner on the inside so hopefully it works out good.
Old Nov 24, 2019 | 09:23 AM
Kfxguy's Avatar
No flex needed. The rubber exhaust mounts will let it grow.
