Boost Juice???
Old Nov 29, 2019 | 11:36 PM
curtisad's Avatar
Default Boost Juice???
Is boost juice any better than window cleaner and HEET?????
Old Nov 30, 2019 | 07:00 AM
80/TA/LT1's Avatar
I can’t speak for heet, but washer fluid is 30 percent methanol, vs boost juice that is 50 percent. I use washer fluid now as my concern was lowering intake temps, didn’t want to rely on boost juice for octane or detonation protection. I’m running 93 octane btw.
Old Dec 1, 2019 | 03:47 PM
94heritage's Avatar
Washer fluid and 2 bottles of heet makes roughly 50/50 and thats all boost juice is.
Old Dec 4, 2019 | 08:26 AM
jaydubb's Avatar
Why not straight methonal? Its been proven multiple times that it cools better and makes more power...
Old Dec 4, 2019 | 08:29 AM
ddnspider's Avatar
anything over 50/50 is flammable.
Old Dec 4, 2019 | 08:33 AM
jaydubb's Avatar
So is gasoline, LOL! i havent seen many meth injection fires. have you? If the tank is secured and tight, would it be a problem? A fuel fire would be just as destructive, wouldnt it?
bct10985's Avatar
so is gasoline
Old Dec 4, 2019 | 08:35 AM
jaydubb's Avatar
Originally Posted by bct10985
so is gasoline
Exactly. I will run 100% meth when my project gets going again...
Old Dec 4, 2019 | 09:49 AM
ddnspider's Avatar
And there are benefits to A) it NOT being flammable and B) injecting water in addition to methanol.
Old Dec 4, 2019 | 01:57 PM
jaydubb's Avatar
I'd rather take the risk...
Old Dec 4, 2019 | 01:59 PM
jaydubb's Avatar
Now when I look at it, maybe its not worth <10 HP... LOL!
Old Dec 4, 2019 | 02:55 PM
Dragframe's Avatar
Thats not true. It can cool the IAT lower than water, but water has the ability to remove far more heat pound for pound. And that’s a fact
Old Dec 4, 2019 | 03:15 PM
ddnspider's Avatar
Ding ding ding.
Old Dec 4, 2019 | 03:20 PM
pdxmotorhead's Avatar
Water+Methanol+Oxygen=alcohol crystals and corrosion.. Make sure that when the injection is off,, its OFF don't just depend on the pump to keep it out of the engine.. A pump with bypass plus a solenoid valve to release the mix..
Just my experience,, YMMV/Eplurbus Unum
Old Dec 4, 2019 | 03:39 PM
ddnspider's Avatar
Er....Caveat emptor? Agree on the solenoid, thats what I do on my DD.
Old Dec 4, 2019 | 08:13 PM
Detoxx03's Avatar
I run 100%. Always have and no reason to stop now.
Old Dec 5, 2019 | 06:57 AM
forcd ind's Avatar
I have been thinking of rem my A/A IC'er, blocks to much radiator, although it really doesnt overheat,
but heats up quick at an idle,and replacing it with a meth kit. I was going to run the boost juice, but was
wondering how long it last as far as losing its meth content. Evaporation?
Old Dec 5, 2019 | 07:23 AM
Formula934's Avatar
I also run 100% meth. The issue as julio at alky control has pointed out many times is flash point temps. Methanol has a lower flash point, i believe you only need approximately 55-60 degrees of air intake temperature for methanol to atomize. This is relatively easy to achieve whereas a water/methanol mix needs higher iats to flash. This isnt really a problem per se with warmer climates but with cold climates you could easily blow a motor with a water/meth combo. Each situation is different and each combo is different. I run 100% meth but im on a stock bottom end, need the added octane and live in a colder climate. To each their own.
Old Dec 5, 2019 | 08:05 AM
Formula934's Avatar
Also see below my conversation with steve williams (aka Frost) one of the best LS tuners on the topic. Back in 2017 when i was putting together my force induction build, he had this to say about methanol.
Old Dec 5, 2019 | 08:29 AM
ddnspider's Avatar
Opinions vary from other highly regarded tuners. Haven't seen Frost on here in quite a while.
