need help asap!! Incon scavenge pump
Answered your PM, it should clear it up and with no drilling.
Gary
If you use it, check the oil level a lot.
You could also route it in the oil drain port. You would install a tee fitting so you could still drain the oil. Oil level sensor was easier for me just because I could reuse the Incon hoses and fittings. I would not rely on the oil level sensor to safe your engine, since the light will not come on until you have a couple of quarts of oil left in the pan. Only problem I have had is that the low oil light wont go off. Even if I delete the code in ls1-edit it will reappear after a few miles. Guess I will have to either pull the bulb or put a resister in the connector.
Gary
