in-line PCV valve
Old Dec 24, 2019 | 08:59 AM
epfatboy's Avatar
Default in-line PCV valve
Pretty sure I want to run a in-line pcv valve on my 4.8 SBE turbo build
Was reading about the fixed orafice style (gm 12572717) and was wondering what the purpose is? As I understand a fixed orafice pcv it "meters" air by using a .010 hole in it, nothing else...
If that is the case why not drop the PCV and run a wide open line?
Here is my PCV routing.
https://photos.app.goo.gl/7q1zJtoxBuSuFMbC6
Old Dec 24, 2019 | 09:15 AM
01CamaroSSTx's Avatar
Why run PCV on a turbo application in the first place! I'll bet most turbo builds are venting to atmosphere.
All your doing by running a PCV system is introducing the blow-by back into the engine and for what reason other than it being a cleaner way to deal with it. Better ring seal and cleaner engine I say
Old Dec 24, 2019 | 10:04 AM
epfatboy's Avatar
Well I am likely boost venting to atmosphere thru my clean air line, no space for a port in front of the turbo due to filter install directly on turbo flange. Plus I don’t know what kind of blow by I’m going to get, it a 97K un-opened SBE and I’d rather not dirty the intake air that much.
It’s also un-metered air as the MAF knows nothing of this air but I’m not sure it that really matters that much, I will tune it this way so It should run well.
The question is however why is the PCV valve recommended especially if it is a fixed orafice design?
Old Dec 24, 2019 | 01:04 PM
truckdoug's Avatar
i use the spring loaded type. open under vac, closed under boost. with a catch can in line. no oil in my intake.
the other side doesnt have a check, just 3/4 hose to a catch can with a breather/filter
works good, keeps **** clean
Old Dec 27, 2019 | 05:37 AM
forcd ind's Avatar
I used VC's that came with my LS3 heads (crate take off) and the D/S just had a nipple that
had a small hole (like the truck PCV valves). I ran a line from that to an oil sep., then to a check
valve, then to the TB. Seems to work OK, I see small amounts of oil in the sep., drain as needed.
