Help me spec twins
Old Feb 1, 2020 | 04:48 PM
newschool72's Avatar
Default Help me spec twins
Im thinking about selling my 72 turbo camaro and picking up a 78-81 el camino as my main ride. I plan to stick a l33 5.3 in the camino and probably back it up with a 4l80e . Im gonna look around and see if i can find an 8.5 10 bolt to replace the 7.5 the el camino comes with too. Plan is to put a set of ported 243s on it and stick a mild turbo cam in it. I want to run a pair of turboes sized to come in pretty quickly, but still spin the l33 to 6500 and not choke it down too bad on the turbine side. I plan to run on the wastegates springs in day to day driving and have my boost controller set on kill at the push of a button .
id be lying if i said it wont see some 1/4 mile action, but the main use would be a fun street car that handles decent , stops good, and can haul trash off or pick up a hand full of 2x4s if i need them.
im not going to have a huge budget, so i will be looking at VSracing or borg warner turbos.
I have a pretty good handle on singles sizing, but not very confident with my judgement on small twins on a 5.3.
Old Feb 2, 2020 | 09:49 AM
Z32_5.3's Avatar
I have 2 eBay gt35s on my 5.3 with 706 heads and all btr head gear. Btr stage 2 cam. Block is .30 over but off brand pistons and stock rods.
http://vi.raptor.ebaydesc.com/ws/eBa...=0&cspheader=1
i put it on dyno few weeks ago before tune to see if everything held together and spool was quick... hit 6psi by 3600rpms BUT it looked like power was dropping off around 5900 rpms. This was with richer than 10.0 air fuel and 9* timing across whole map. Hopefully when tuned it changes but for now it seems like I should’ve gotten alittle bigger hot side.
Old Feb 2, 2020 | 02:00 PM
So a 62mm t4 exhaust is too small ? Im glad i started this thread cause i would have thought that would have been enough wheel for a 2.65 liter 4 cylinder at 6500 rpms. Maybe i should be looking at something in the 68mm exducer turbine in a t4, or better yet, a v band exhaust flange. Thanks for the responce.
Old Feb 2, 2020 | 03:52 PM
Bad Apache's Avatar
ls1tech.com/forums/forced-induction/1797340-i-am-having-twins.html
ls1tech.com/forums/forced-induction/1816407-twin-turbo-33-pickup.html
Couple good reads there. Tom's car was drag race only but ran very well and spooled quickly.
Old Feb 2, 2020 | 04:00 PM
Z32_5.3's Avatar
these exact turbos were used in 2 other threads on this site. One made 748whp on them. That’s why I purchased them. I’m not sure why they run out of steam so soon for me. I’m really hoping tune clears it up but afew people were at dyno that day and told me the hotside was just too small.
Old Feb 2, 2020 | 04:07 PM
AwesomeAuto's Avatar
No. I made tons of power with twins that had 56mm wheels in a tiny T3 housing.
Old Feb 2, 2020 | 11:40 PM
jordoza's Avatar
richer then 10.0 afr and 9* of timing. Thats why it fell on its face. Tune it and it will kick ***. I cant speak for the rest of you hotside but those turbos are not to small.
Old Feb 3, 2020 | 12:29 AM
Z32_5.3's Avatar
awesome! I’m almost ready for tune. This makes me feel better lol.
Old Feb 3, 2020 | 01:07 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
No kidding. People try to stay safe, but that is ridiculous. At that AFR and timing nothing will make power.
Old Feb 3, 2020 | 07:28 AM
Z32_5.3's Avatar
it made like 451 after putting the correct springs in. I don’t drive it now though. It was only to make sure I had no motor issues cause all custom stuff done. Found 2 hotside leaks and dropping car off to get exhaust done today actually.
it was just a generic basemap for me to put some miles on clutch and test out swap. I’m excited for what it does when my tuner actually touches it.
Old Feb 3, 2020 | 07:56 AM
Your AFR and timing are insanely low. I'm surprised it even made as much as it did.
