The Nova is back for 2020
Old Feb 17, 2020 | 02:36 PM
RonSSNova's Avatar
Also a PTC 9.5. I think it’s a 17.
a little loose, but works fine with the foot brake.
Old Feb 17, 2020 | 03:31 PM
yenkomike's Avatar
I hope with a 6.0 and a trans break the 15 will work . im sure if it will build boost it will run good with the steeper 1st gear in my 400th im used to a 1.76 glide.
Old Feb 17, 2020 | 03:46 PM
jordoza's Avatar
Good luck brother. glad to see you got it up and going again.
Old Feb 17, 2020 | 04:01 PM
RonSSNova's Avatar
Thanks! 9 runs in two years was not acceptable. 😊
Old Feb 17, 2020 | 04:04 PM
RonSSNova's Avatar
Originally Posted by pete466ss
What mod was that?
File a slot in the bearing shell at the parting line to feed some oil to the the thrust surface. An old trick. To some it’s controversial in the LS world.
Old Feb 17, 2020 | 04:27 PM
jayyyw's Avatar
My engine builder did that mod on my SBE engine because I mentioned that I might switch to a powerglide.
Old Feb 18, 2020 | 11:59 AM
3 window's Avatar
It’ll build boost fine. I had a 15-40 (tighter) behind my 5.3 and it’d build 20 psi in under two seconds if I wanted it to. Just too tight everywhere else.
Old Feb 18, 2020 | 12:03 PM
3 window's Avatar
No real good way to trim the excess is there? They have caused blood for sure. But some bleeding is required when building hot rods!
Get some small needle nose pliers and make a tiny curl at the end. I’ve used the stainless zip ties and baling wire for exhaust wrap. I always use the curly end trick on both. Works great.
Old Feb 18, 2020 | 11:19 PM
truckdoug's Avatar
stainless steel aircraft safety wire
no more blood must be shed!
Old Mar 18, 2020 | 10:47 AM
RonSSNova's Avatar
Well, 2 dragstrips in the Portland area. Due to the virus, both closed for the foreseeable future.
Crap!
Old Mar 18, 2020 | 10:56 AM
Quito195's Avatar
Yep, I was getting my junk all dolled up for the roadster show, and then to start racing (until PIR boots me lol) and its all closed now......
Old Mar 18, 2020 | 01:26 PM
  #32
01CamaroSSTx's Avatar
Total BS
Have four tickets to the NHRA Texas Sportsman Challenge and that's closed down due to COVID-19.
NHRA Spring Nationals are still on the agenda so as long as they don't close that one down I'll get over it!
Old Mar 18, 2020 | 08:51 PM
  #33
17outs's Avatar
Would love to see any graphs on the curve with that turbo.
Old Mar 18, 2020 | 09:08 PM
  #34
RonSSNova's Avatar
Sadly, even though I am, or was I should say, a dyno operator, I never got it on there.
Track and street tuning only.
Maybe someday!
Old Mar 19, 2020 | 06:31 AM
  #35
forcd ind's Avatar
All the tracks, meets around here are shut down, some tracks are doing rentals only. One big event I go to
every year in May is still undecided. I have been puttin around on the streets, not much traffic since nobody
is working. With my 401K in the crapper, I drive easy so I dont break parts, lol.
Old Mar 20, 2020 | 08:32 AM
  #36
truckdoug's Avatar
yeah everything is shut down. waiting for a shelter in place order.
there are upsides of course. PPD is no longer responding to anything that is not immediately life-threatening violence.
and as it turns out, complex hydrocarbons in the form of tire smoke seems to kill the virus on contact
