Garrett Turbo selection for a 6.2 ls9
Old Feb 17, 2020 | 03:39 PM
C Murda's Avatar
Default Garrett Turbo selection for a 6.2 ls9
got a sweet LS swap GMC syclone project im doing using a built Darton sleeved LS9 block (gonna find the limits of these blocks with dartons). truck will be a max race weight of around 4000lbs and ill be looking for a twin BB Garrett set up with 1600whp potential that spools quickly. I have no idea how to properly spec a turbo out so looking for advice from the pros.. Currently looking at the GTW3684R turbo if any one knows if that should work for my goals and application? also what A/R? t3 or t4? divided or undivided?
Old Feb 17, 2020 | 09:17 PM
jordoza's Avatar
It takes 160 to 170 lbs/min to make 1600rwhp. That turbo even as twins makes 120 maybe 140 if pushed extra hard.
Old Feb 18, 2020 | 01:18 AM
chuntington101's Avatar
How about the new g series turbos? Maybe 2 of the g35-900s? Not sure how they compare in price to the old GTX stuff.
Old Feb 18, 2020 | 08:49 AM
SLOW SEDAN's Avatar
x2 the referenced turbo is basically a 62/62. If the op wants to stick with Garretts GTW line then I would do at least the GTW3884 as that will get him closer to the proposed goals.
Also for the OP - no reason to use divided turbines on a LS twin turbo setup.
Old Feb 18, 2020 | 08:58 AM
93hatch's Avatar
why you stuck on garret did they send you a sticker or something
Old Feb 20, 2020 | 11:25 AM
Jimbo1367's Avatar
Two stickers.
Old Feb 21, 2020 | 04:23 PM
stevieturbo's Avatar
The GTW's dont seem too unreasonably priced and they seem compact ( not as compact as the G series though )
But there are no lack of turbo options of any type these days !
By Brett Foote | 2026-06-04 05:00:17
