Running lean sometimes??!
Old Mar 16, 2020 | 09:53 AM
Khalifaa's Avatar
Default Running lean sometimes??!
Soo just got my car from the dyno it’s a ls2 GMC Sierra with s475 turbo it made good power at 13.5 psi (656 on an MD) but when tested on the road some times it has good afr (about 11.3) in some runs and sometimes it goes lean about 12.9 afr and I can hear the detonation clicking sound the car has stock fuel system other than ID 1000 injectors and duel nozzle methanol system 100% meth.
i don’t know what I should check I already checked the meth system seems fine and the injectors at 60% duty cycle.
any ideas what it could be.
Btw the car still occasionally run fine not lean at all.
Old Mar 16, 2020 | 10:00 AM
Dragframe's Avatar
stock fuel system? I’d say you are out of pump man. 500rwhp is as far (further actually) as I’d trust the factory pump. What’s your fuel pressure when it goes lean?
Old Mar 16, 2020 | 02:36 PM
Khalifaa's Avatar
I have to run it on the dyno and check it with my tuner but I’m sure it was fine on the dyno. Currently I’m testing the meth nozzles to see if there are any restrictions from them. After that I’m checking the fuel pressure
Old Mar 16, 2020 | 03:51 PM
Dragframe's Avatar
That’s a big reason I never have had meth injection. If there is a problem, and you don’t have a pressure switch that will revert boost to wastegate when the meth pump fails, your gunna have a bad time.
but personally... No question about it... I’d Upgrade the pump. A Walbro 450 will only support around 700rwhp on petrol... your running that on a stock pump which is crazy unless you have a flex fuel pump. And even then I wouldn’t be comfortable with it. I know you have meth... but that’s not a smart way to fuel for extra power. Don’t use it as a primary fueling source...
$130-150 is all a walbro 450 or 525 will cost. Regardless of it being the problem or not, upgrading your fuel pump is mandatory at those power levels.
Old Mar 16, 2020 | 04:21 PM
Khalifaa's Avatar
part of the reason I use meth is because I live in a country which the weather is really harsh for turbo cars 90-100 degrees at night so the IAT goes waaay up when I step on it + we don’t have access to e85 fuel so I use meth but I will look into the new walbro 525 what kind of hp it will take. Thanks for the info
Old Mar 16, 2020 | 04:36 PM
GMCGreg's Avatar
Does the lean running coincide with a lower fuel level or higher Gs ? Could be uncovering the pump ? There is no g force or fuel slosh on the dyno. Not sure the stock filter is up to the task either
Old Mar 16, 2020 | 04:40 PM
Khalifaa's Avatar
it could be because I tried with a full tank it was fun but with a quarter tank it went lean maybe this explains why it was ok on the dyno
Old Mar 16, 2020 | 07:00 PM
ddnspider's Avatar
That meth is the only reason the motor hasn't detonated itself to death. You need a pump and hotwire kit and log fuel pressure.
Old Mar 16, 2020 | 07:15 PM
Khalifaa's Avatar
any suggestion for a fuel system for my 2013 Silverado I want to convert it to return style. If there is someone who builds fuel system for my car please recommend him to me.
Old Mar 16, 2020 | 08:01 PM
ddnspider's Avatar
Take a look at @denmah on here and his Sloppy Mechanics page. Should give you ideas based on goals.
Old Mar 16, 2020 | 09:57 PM
jordoza's Avatar
I just saw a youtube from sloppy outlining a 3 pump deal for his current truck build. It was really trick. Check it. Hope posting the lonk doesnt break the rules its a link to denmah not a seller exactly.
Old Mar 16, 2020 | 11:54 PM
Khalifaa's Avatar
https://youtu.be/96vpSBQQxw8
I will check him out
thanks
Old Mar 17, 2020 | 11:50 AM
GMCGreg's Avatar
I don't think you're gonna need that much pump , I'm sure Matt is going for some big numbers. A single 450 should do it, but you have to keep the pick up submerged. If you don't see any lean out with > 1/2 tank fuel there's your solution, or look into improved baffling in the tank. As far as fuel regulator , the old design factory rails with vac reference has been used at that power level successfully on pump gas. Probably have to retune though
Old Mar 19, 2020 | 04:43 PM
Khalifaa's Avatar
Update!
checked the car today with my tuner and we logged a run, apparently the voltage drops sometimes to 11.4 when that happens the fuel pressure drops to 33 psi now I’m looking into this issue I think my alternator is about to give or maybe it’s a wiring issue thinking about getting a performance alternator what do u guys think.
btw the my flex fuel pump is still good at this power level it only drops when the voltage drop.
Old Mar 19, 2020 | 05:17 PM
tblentrprz's Avatar
Can you log voltage? Start by logging alt output. If good, then pump voltage. Figure out where going low and.. remember, voltage drop can occur on NEG side as well as POS side.
Old Mar 20, 2020 | 08:19 AM
GMCGreg's Avatar
Quite a few of the people here have had voltage problems (not me fortunately ) , from what I've read the cure is usually, new alternator, modified alternator wiring, or larger alternator pully - apparently they stop charging at higher rpms. In no particular order.
Old Mar 20, 2020 | 09:34 AM
Khalifaa's Avatar
I will try to get my buddy’s alternator and test the car, if the alternator was the problem I will get a new one, I don’t really trust the remanufactured ac delco stuff maybe I will get a performance alt from mechman.
Old Mar 20, 2020 | 06:13 PM
stevieturbo's Avatar
Update!
No. You need a proper fuel system, pump, wiring etc.
Now, you may also have an alternator issue, but a stock fuel system and ID1000 injectors is a bizarre setup
Old Mar 20, 2020 | 07:09 PM
Khalifaa's Avatar
definitely I’m now looking for a good fuel sys for the truck surely I will be converting to return fuel system I will get an aeromotive regulator re use the the stock line as a return line 8AN feed line only thing I’m not sure whether I should get the double pumps fuel hat from horsepower headquarters and do a twin walbro 450 or I just try the new 525 hellcat pump.
Old Mar 21, 2020 | 05:30 AM
At only 650hp, I cannot see any need for a pair of 450's
A pair of 255's would easily support it.
Or a single 450 or 525.
Yes you should build in extra capacity, but it doesnt make sense to go overboard either.
